Pay per view on Viewsat Plat
Username: Pegg
Post Number: 31
I am getting just on PPV at 502. what happened to others? Did blind scan as well did not help.
Username: Albino_midget
Post Number: 348
thats the only one left at 119w
others either removed or are now at 110w
Username: Mc_sunny
Post Number: 881
just do factory default then rescan,When you are going to scan bird 119 make sure your tp frequency is adjusted to 12239 if its not adjusted to this before you scan you will miss tons of channels,dealers are sometimes forgetting to inform there customers of this and alot of confusion can result!
119=TP Freq-12239
110=TP Freq-12224
91=TP Freq-12224
EchoStar 7 - 119. ECHO 7
LNB Power------ON
LNB Type-------Standard For dish pro set to OCS
LNB Freq-----------11250
22kHz-------------Off unless you have a 22kHz switch turn on.
TP Freq----------12239
Search option-----All
DiSEqC 1.0------Port 1
Motor--------------Off
Legacy SW------None
Username: Pegg
Post Number: 32
Thanks. My TP setting for 119 is 12224. When I changed it to 12239 it did not allow me to save and when I come back it still shows 12224.
Username: Trucker
Post Number: 58
"pegg mcintosh" 502 is the only movie ppv left on 119w all others are on 110w, like albino midget said above. dn has been moving a lot channels around the last few days.
