How to factory flash VS2000 extreme
Username: Hamtec
Post Number: 623
Can anyone shed some light on Factory flashing a VS2000 extreme.
Username: Sitsat
Post Number: 55
Colin, click menu on the remote, select installation, select factory default....please remember this will delete all your channels.
Also, load factory bin 2068 before reloading the new bin you want to load. Make sure you give enough time to reboot the mechine itself after installtion. Do not turn off the receiver unless u r absolutely sure the bin is loaded and the stb reset itself.
Hope this is helpful.
Username: Hamtec
Post Number: 625
Where can I fine bin 2068
Username: Mc_sunny
Post Number: 761
2068 Extreme Factory Bin, when u open this link just scroll down all the way and it will be the last one
http://www.dssrookie.com/forums/b-font-color-cd2626-vs-xtreme-files-font-b/views at-xtreme-factory-bins-73413.html
Username: Mc_sunny
Post Number: 762
Viewsat Flash Process
this is a 11 step flash process
1. unzip the files in a viewsat folder
2. click on the program " loader 2 "
3. click " open files"
4. go to the directory where you keep your files and select
5. click on tool, click on configuration -select comm port
6. click off file
7.click pc>stb then plug in your viewsat power.
8. once it is completed, the program will say "0000"
9.power off your viewsat.
10. connect your vsat to your tv and enjoy
11. read your user manual.
if you have a DP LNB then this is your setup. if other than DP select "standard" for the LNB .....
110:
LNB power on
LNB type OCS-DP
lnb freq. 11250
22 khz off
TP freq.12224
search option ALL
disecq port 2
motor off
119:
LNB power on
LNB type OCS-DP
LNB freq. 11250
22 khz off
TP freq. 12224
search option ALL
