PANSAT 2700A - Autoroll FIX????
Username: 1llu5ion
Post Number: 8
Hello Everyone,
I have Pansat 2700A.
Is there a bin (reliable) with auto roll fix out there for this receiver?
Many Thanks in advance.
Username: Albino_midget
Post Number: 321
new bin released 11/14
Username: Lklives
Post Number: 5712
found this in the archives...
U don't say anything relevant...EPG usually is good for 2 hrs ...If U have date, time and time zone correct U will get that on the Pansat..
This works on the Pansat 5000 and 6000...and works on many channels with the 3500...try it on the 2700..it is NOT a fix for the date and time though!
By the way if you want the EPG to update (give you two days of programming) then you should hit EPG while on any channel on TP 19 (CNN, HNN, HBO-W or SHOW-TOO all work). Otherwise the EPG shows the next two shows on each channel.
Username: Osc
PUERTO RICO
Post Number: 330
There's a new fix for pansat 2700
http://www.future-fta.info/Forums/showthread.php?t=38075
Yes! We have the fix for latest autoroll issue from DN.
Enjoy!
Regards,
Blacklist
