Downloading files
Username: Asjjca
Post Number: 12
Hi I have a multistar which is a clone of the pansat. I have the blacklist updater but when I download the files for the new program do I need to unzip them and if so with what? Otherwise do I just download the whole file into the receiver. I try downloading the pansat 2500. I would really appreciate some help. Thank you!
Username: Minn_rock
Post Number: 621
GO TO SEARCH ON GOOGLE FOR "WINZIP OR WINRAR" THAT WILL UNZIP 4 U..
Username: Asjjca
Post Number: 13
Thank you for your reply. I downloaded winrar and I am still having problems. It is downloading properly now but I think I may be downloading the wrong program. Do you know which program I would have to download for the multistar receiver? Thank you.
Username: Johnner
Miami, Florida
Post Number: 947
There are many freeware versions as well
http://www.download.com/3120-2001_4-0-1-0.html?qt=zip&author=&titlename=&desc=&d lcount=&daysback=&swlink=&gfiletype=&os=&li=49&dlsize=&ca=
Username: Johnner
Miami, Florida
Post Number: 948
If it is a Pansat 2500a Clone!
http://www.dssrookie.com/forums/attachment.php?attachmentid=55414&d=1162610685
Username: Asjjca
Post Number: 14
The problem is I'm not sure some say it's a pansat clone or a pantec clone. How can I tell?
Username: Lklives
Post Number: 5259
Pantec is basically a clone of Pansat..there is a specialized Pantec site that U should use...register for free...and small annual fee doe VIP and files..
Pantecs are all different and have different guts...yours is a Pansat 2500 clone and should use bin 284T, which is found everywhere at REPUTABLE DSS sites!..
or u should just start reading about the Pansat 2500 setup manuals and guides..
[link removed]
Username: Asjjca
Post Number: 15
Thank you very much. I really apreciate all your help!! :-)
Username: Inderji
i hav pansat 3000 and using loader v1.4 and bin 284t but cannot load a bin.some one help me 2 load a bin plze
Username: Lklives
Post Number: 5264
If U cannot load a bin, the simplest thing in FTA...then U either need to READ more or subscribe!
Username: Hanz
Post Number: 31
What do we subscribe to, LK? :-)
Username: Lklives
Post Number: 5265
U are a piece of work...go away!
Username: Minn_rock
Post Number: 622
DN OR DTV OR CABLE..MAYBE RENT SOME DVD..LOL.
Username: Hanz
Post Number: 41
Thanks LK. :-)
Username: Themangod
Post Number: 19
yea [link removed] for clones
pantecf2a is not good they dont offer free download or even view of board with out membership.
