Pansat 3500sd
Username: Bh4v
Post Number: 15
Is any1 pansat box workin cuz mine isn't even wit the new keys
Username: Dude123
Post Number: 484
they are all working fine make sure you have the right bin file.
NOTE: if you are using one of the older bin files then you need to keep your autoroll off, keep key code ON only and leave everything else off and with the following keys you should get TV
Good Luck!!
Nagra2 Keys
Dish Provider 0101: Last Updated (Nov3 6pm EST)
Key0: 5F 3A 47 57 E9 54 99 FC E9 F9 0C 81 41 EC 9B 83
Key1: AC AF 66 4C D5 81 CA 92 85 FB 40 B3 CC 01 99 2D (Active)
Bev Provider 0901: Last Updated (Nov5 9am EST)
key0: F6 3D F2 E4 CE 6E 22 44 6B 87 79 6F 66 7C 3F 8E (Active)
Key1: B5 53 D5 4F DB B8 55 EB 53 60 C1 D7 AA B3 A6 81
Username: Johnner
Miami, Florida
Post Number: 945
New 3500sd BIN
http://www.dss
central.net/files/uploads/Pansat3500-X-05BL%20Loader%20v3.40%20[X-05BL].zip
Username: Lklives
Post Number: 5258
367 is latest Pansat 3500 bin
Username: Johnner
Miami, Florida
Post Number: 950
Oppsss... Wrong File Here 367
http://www.dss
central.net/files/uploads/X-05BL_061102_367eubx_api.zip
