Is there an autoroll for co*lsat?
Username: Kille
is there a bin out there for a co*lsat5000 that has autoroll?, and if so where?
Username: Lklives
Post Number: 5037
Bin 135 since 10-11...at any reputable Dss site!
Username: Lklives
Post Number: 5171
copy/paste..works on all Coo*lsats..
If you have trouble with autoroll on Coo*lsat
NVRAM Cleaning Helps AutoRoll
I'm running a CS6k with 135 and was having trouble with the autoroll not working. I had to hard boot, i.e. turn off the CS with the switch in the back, every time the keys changed.
I cleaned out my NVRAM and that problem has gone away, now autoroll works fine.
To clean out your NVRAM, hold the power button on the STB and press the up channel button. You will get a new menu that you may not have seen before. Navigate to the NVRAM with the arrow keys on your remote and when highlighted hit select. This will clean out the NVRAM.
this is like doing a database reset so
when your done redo all your settings then autoscan you'll be good to go
i have tried this and it works
Username: Lklives
Post Number: 5190
bump
Username: Jrq
Post Number: 160
Very good piece of info this. Should take away some frustration for a lot of folks.
Username: Fidarahman
Post Number: 78
This works and the keys change both for DN and B*v, but some channels on DN and all on B*v go black at times..although the keys change to the latest.Can you explain how can we overcome that please?This is regarding CS 4000pro
