NEW KEYS
Username: R1010
Post Number: 73
KEY 01:
15 D3 DO 77 55 73 07 BD
D3 BC 59 21 C7 9E C0 14
Username: Jerseynigga007
Post Number: 18
Nagra2 Keys
Dish Provider 0101: Last Updated (Nov1 7pm)
Key0: 54 C5 70<becomes>21 A6 4B 71 2C 68 2C EA 36 CE 04 E8 ED 75 (Active)
Key1: 15 D3 D0 77 55 73 07 BD D3 BC 59 21 C7 9E C0 14
Post Number: 19
Nagra2 Keys
Key0: 54 C5 21 A6 4B 71 2C 68 2C EA 36 CE 04 E8 ED 75 (Active)
Username: Kingofdakingz
Post Number: 7
the keys dont work anymore
Username: Ars88
no the keys work fine its just that you have to replace the current key in 01 line 2 with 9E the only thing that gets replaced is the 9E everything else is the same
thanks for the keys!
Username: Pizda
Post Number: 37
15 D3 D0 77 55 73 07 BD D3 BC 59 21 C7 <<9e>> C0 14
Username: Televisat
What are the settings for koolsat 5000 in the installation setup using DP TWIN LNB when picking sats echo 7 & echo 8,6?
