Why this is happening to autoroll
Username: Yanniss
Post Number: 92
why pansat 2500 and 2700 with the latest autorol dont roll today we have to change one key . any help suggsested thanx .
Username: Youngdragun
Somewhere in the usa, Usa Usa
Post Number: 23
Well I'm glad to see that i am not the only one affected. but I'm said that i can not help you.
Username: Charjam
Post Number: 77
Yea i would like to know why it didn't roll, The same thing happened last week with my 2500
Post Number: 25
Albino Midget
Username: Albino_midget
Post Number: 295
Posted on Wednesday, November 01, 2006 - 09:26 pm:
same problem- different solution
you turn autoroll off and adjust the 01 key:
15 D3 D0 77 55 73 07 BD
D3 BC 59 21 C7 <<9e>> C0 14
Posted by Albino Midget. this temp solution worked for me, my assumption is that every couple of autorolls or every new autoroll for panset 2500's is somehow not in sync maybe a reload of the bin will work or maybe blacklist is working on a fix. anyways just use the temp solution as it has worked for me.Cheers.
Username: Edenman
Post Number: 113
yup, autoroll back down on my 2700 clone after only 2 days!! lol Pansat sucks. VS with new bin rolls nicely.
Username: Letmeon
Post Number: 78
is that 283t bin. Pantec Ukltras MX
I have the same prob. havenot prog 283t, using an older one 281t.......
