HOW do you manually enter keys for viewsat extreme
Username: Quicksilver_112
Post Number: 32
How do u enter the keys menaually into a viewsat extreme and what are the newest keys that are or should go in...?
Username: Hamtec
Post Number: 618
install newest auto roll fix for VS.
Username: Filetester
Deep down, Up there Canada
Post Number: 13
MANUAL Public Key Change
The Public Keys have changed go to [link removed] to get the new keys.
THESE ARE NOT THE KEYS JUST FOR POST..GET KEYS OFF KEYS PAGE
Key 00: AF 98 74 44 1C 65 77 D8
Key 01: AF E3 E1 1D 89 4E 53 45
On the REMOTE CONTROL, you'll be using the 0 through 9 keys for the number
you need and...
A = F1
B = F2
C = F3
D = F4
E = "LAST" key (circular arrow key to RIGHT of "0" )
F = "TEXT" key (2 rows ABOVE F4 key on right side of REMOTE)
TO MAKE A MANUAL KEY CHANGE in your ViewSat:
MENU--INSTALLATION--CODE--NAGRA
LEFT arrow until "Dish" displays in the top line and you have at least 4
ROWS of numbers like below. The 4 rows we are most interested in are:
08 xx xx xx xx xx xx xx xx
09 xx xx xx xx xx xx xx xx
88 xx xx xx xx xx xx xx xx
89 xx xx xx xx xx xx xx xx
DOWN arrow until the RED is on "08"
RIGHT arrow x 1 puts you on the "08" line of numbers in the 2nd column
"F1" + "Text" = "AF", RIGHT arrow
"9" + "8" = "98", RIGHT arrow
"7" + "4" = "74", RIGHT arrow
"4" + "4" = "44", RIGHT arrow
"1" + "F3" key = "1C", RIGHT arrow
"6" + "5" = "65", RIGHT arrow
"7" + "7" = "77", RIGHT arrow
"F4" key + "8" = "D8", RIGHT arrow ... finishing the top line.
You should have the highlighted box in the first column of the 2nd row on
top of "08"
DOWN arrow x 1 and RIGHT arrow x 1 to the 2nd box in the "09" row
"LAST CHANNEL" key (below "9" key) + "3" = "E3", RIGHT arrow
"LAST CHANNEL" key (below "9" key) + "1" = "E1", RIGHT arrow
"1" + "F4" key = "1D", RIGHT arrow
"8" + "9" = "89", RIGHT arrow
"4" + "LAST CHANNEL" key = "4E", RIGHT arrow
"5" + "3" = "53", RIGHT arrow
"4" + "5" = "45", RIGHT arrow
EXIT, OK ("YES") to save
EXIT to TV screen and watch tv
This puts the PRETEND KEYS into the 08 & 09 KEY lines.
If you need to put KEYS into the 88 & 89 KEY lines... do above and
substitute "88" for the "08" line and "89" for the "09" line.
Copy and paste from [link removed]
Username: Lklives
Post Number: 4674
We at dsscommunity.c*om have ADDED this to the above..REMOVE the * in the links!
[link removed]
A little info for you first...
A character can be a number or a letter, and 2 of them together = hex pair
There are 32 Characters found in a Key and they are split into 16 hex pairs.
Those 16 hex pairs are divided into 2 rows with 8 hex pairs in each.
Hence each key, like Key 00 and key 01 has a string of 2 rows with 8 hex pairs in each.
Here's how to enter them...
For DN
Remote --> Menu --> Installation --> Code --> Nagra
Choose --> Dish 01 01 00
There are 5 rows. Ignore the first (top) row.
And, ignore the first pair of numbers in each row.
00 xx xx xx xx xx xx xx xx (ignore)
Row 08 = the start of Key 00 and has a string of 8 hex pairs, with 8 more in row 09
Row 88 = the start of Key 01 and has a string of 8 hex pairs, with 8 more in row 89
For BEV
Choose --> BEV 09 01 00
There are four rows; ignore the first pair of numbers in each row.
08 xx xx xx xx xx xx xx xx (Key 00)
88 xx xx xx xx xx xx xx xx (Key 01
You can find the keys in the Current Keys Section for DN and Bev
Additionally, the password will be 0000.
To enter the letters:
A = F1 (Red Button)
B = F2 (Green Button)
C = F3 (Orange Button)
D = F4 (Blue Button)
E = Go Back Button (Right side of remote, 6 buttons down)
F = Text Button (or Color depending on remote. Right side of remote, 5 buttons up)
When you finish entering the keys, exit out of the screen. You will be prompted asking if you want to save (Yes).
Exit back to where your channels are and enjoy.
