ViewSat Xtreme 2000/Adding Transponders manually
Username: Zizu
How do I "MANUALLY" add 119, and 91 ? In other words, at the antenna setup menu, thee EchoStar 8,10 110 is working right now using port 2, what are the setting for 119 and 91 (LNB freq, TP freq...etc) ?
Tried putting the new satinfo file from the latest fix but it messed up my listings...
Username: The_only_one
Post Number: 19
does anyone know how to do a TP scan?
thanks in advance
Username: Zizu
Just press F1 at the transponder you want to search in in the Antenna setup menu.
Post Number: 22
o ok so i just do a channel scan. thanks
