Real new coo lsat 4000 bin/fix here
Username: Tvtech3
Post Number: 124
http://www.dssmax.com/forums/showthread.php?s=&postid=61368#post61368
Username: Tvtech3
Post Number: 125
o and sorry for the delay as i had 11 webpages open at once so when the big man sentit to me it took me forever to getit uploaded
Username: Fastbeatz
Post Number: 81
so this works? and its for cardless right???
Username: Tvtech3
Post Number: 126
absolutly ;-)
Username: Hackdark
Post Number: 13
did this works on clone? (digisat4000pro)
Username: Hackdark
Post Number: 14
plz, some one, if this ok to clones?
Username: Hackdark
Post Number: 15
plz, someone, is this ok to clones?
Username: Hackdark
Post Number: 16
plz, someone, is this ok to clones? or it will frezze my reciver?
Username: Tvtech3
Post Number: 127
try it and see
Username: Hackdark
Post Number: 18
ok, I will try... let`s hope...
Username: Tvtech3
Post Number: 128
letus know ;-)
Username: Tvtech3
Post Number: 129
any luck tony?
Username: Tvtech3
Post Number: 130
mustve worked as he wont reply lol
Username: Tvtech3
Post Number: 131
earth to tony come in tony
AHHHH SHUZZBUTT
Username: 99centrobot
Chicago, Illinois
Post Number: 66
thanks jack off...you promised and you delivered.
very cool.
Username: Tvtech3
Post Number: 133
well was earlier than expected actually
Username: Tvtech3
Post Number: 137
tony still callin tony lol
Username: Cbman
Denton, Nc Davidson
Post Number: 12
need bin file for colsat clones (coocoo) (digisat)can anyone help me please
Username: Tvtech3
Post Number: 140
cool sat clone fix is here
https://www.ecoustics.com/electronics/forum/home-video/35.html
Username: Tvtech3
Post Number: 151
please post back your results for others
Username: Chico
Post Number: 64
loaded 131 bin-file into 4000pro.
seem a little bit slower when changing channels not real sure why. does anyone know why? this is not a complaint just a observation. everything else seems to be fine.
Username: Tvtech3
Post Number: 152
actually even legal subbed systems are saying the same thing
Username: Chico
Post Number: 65
is it because the map calls taking up a little to much resource on the processor? just a guess.
Username: Tvtech3
Post Number: 153
dont think so as i said its affecting legal setups to
Username: Lichmc
Post Number: 15
http://www.tranlich.com/dss/01oct2006/
01 OCT 2006
We can watch all of channel ppv .. with new bin and donot have to change for new keys
*** remember to wait 10 minutes for receiver to update all channels
1) For Megasat Yt and Pansat 2500A
*** Use Megasat Updater 1.50 in software folder
*** Load bin:
megasat_pansat2500_01oct2006.bin
make sure it has 640kb
*** After finishing loading, (Press menu, Parental Control, Second Bin, 0000, Set Default, Exit ,Exit)
*** Keys and Channels will be automatically updated after 10 minutes
*** Enjoy the momvie. You can rescan each Satellite 110, 119, Telstar 5 every month for new channels.
If you lose some, reload my channel list
2) For Megasat Pro, Co*olsat, and Cooltec
** Use Cooltec STB Loader.exe in software folder
*** Load bin:
megasatpro_coolsatclone_cooltec.STB
*** After finishing loading, go to channel 7 and wait for 10 minutes. Keys and Channels will be automatically updated
*** Enjoy the momvie. You can RE-SCAN each Satellite 110, 119, Telstar 5 every month for new channels.
email me if you have trouble
