What is on 61.5 if there is still 1
Username: Firple
Post Number: 10
what is on 61.5 and how come i am not getting it in on my pansat with the new bin ? i havent moved it in the dish in months.and i use this set up strictly for indian channels
Username: Firple
Post Number: 11
what is the correct cinfiguration for this? i have only 1 dish and i only want 61.5 i have a pansat 2700
Username: Nydas
Post Number: 689
Check the BIN date in system info to confirm that the new BIN is there.
Go to Menu/Antenna, Echo3, and make sure that in the right panel you have a disEqC connection (1,2,3 or 4) and you are seeing a signal strength of over 75%.
Put in the new Keys for Nagravision 2 - both Key 00 and Key 01.
Turn autoroll off. There are some ECM problems with autoroll on today.
Then do a blind scan.
