Pansat clone 2500 er1 fail
Username: Ganga
have a pansat 2500 clone; loader 1.4 with 279t bin; once I load it says failed er1, any suggestion
Username: Simikang
Post Number: 74
check your com port or your wire or if the receiver is on from the back
Username: Nikk
Post Number: 297
For a 2500 you need to use a RS232 straight cable, that's probably the problem you have, check what kind of cable you are using....
