How do i load a new bin into my 2500
Username: Crook18
Miami, Fl Us
???newbie but gotta star somewhere
Username: Nikk
Post Number: 138
Danny...
First of all, go to Radio Shack and get a DB9 female to DB9 female RS232 cable, this one is also known as 1 to 1 cable, after that get the blacklist uploader and the 279 bin....connect the cable to the serial port on your PC and to the receiver, turno on the receiver and open the uploader, browse for the 279 bin and do a write it to the receiver.....
Username: Nikk
Post Number: 139
BlackList Loader... click on this link...u have to sign up first
http://www.dssevolution.com/forums/showthread.php?t=79073
Username: Hawaiian_time
Hawaii
Post Number: 619
First make sure you don't have a clone.
Username: Nikk
Post Number: 150
Hawaiian is right...
First of all, check what kind of receiver u have....
Username: Pjk
Post Number: 82
Do all pc's have serial ports with the pins or are the new ones ubs's only?
Username: Nikk
Post Number: 166
pjk...
Most of the new PC's still have one serial port, most of the new Laptops don't....
Username: Nfl
Post Number: 43
for home use laptops don't come with serial port. Work or corporate laptops do have one serial port, new or old. All desktops should have serial ports. Need new bin and uploader, go to www.chochcrib.net/forums/ no sign up required, all files are working, I have tested myself.
Username: Ddyy
the_nfl
I'm new to this tool, could you tell me what do you type in "STB Model" text box?
Thanks
Username: Nikk
Post Number: 236
Splash...
Go and take a look at the second post of this thread, it explains all if you are using the 1.4 loader, take a look on there, it will tell you what you need.
https://www.ecoustics.com/electronics/forum/home-video/274281.html
Username: Jerry711
Throop, Pa. U.s.
Post Number: 60
holy fu2k
