Username: Rkanak Post Number: 105 Registered: Jun-06
Wednesday, September 27, 2006 - 18:25 GMT I saw Ariza files on totalfta, but doesnt have an access to download it.. if somebody could confirm it, here is the link http://www.totalfta.com/showthread.php?t=19432
Username: Rkanak Post Number: 106 Registered: Jun-06
Wednesday, September 27, 2006 - 18:31 GMT wel finally its there on Al7bar dot tk here is the link for Ariza 700 http://www.al7bar dot tk/Forums/showthread.php?t=178010
Username: Pathfinder191 Post Number: 71 Registered: Mar-06
Wednesday, September 27, 2006 - 19:14 GMT Are they working?
Username: Rkanak Post Number: 110 Registered: Jun-06
Wednesday, September 27, 2006 - 19:57 GMT yes, confirmed working..
Username: Diskos Post Number: 2 Registered: Sep-06
Wednesday, September 27, 2006 - 22:28 GMT Anybody noticed that the STB model even if you selected 700 changes to ASR 3530 after the bin (280) selection.Is it going to work?
Username: Nydas Post Number: 606 Registered: Jun-06
Wednesday, September 27, 2006 - 22:53 GMT 2.80 - Ariza 700 - Fix - 09/27/06 [link removed] AA-1_H20060927_280eEU(N)_api.zip (0.7 MB) 2.80 - Ariza 750 - Fix - 09/27/06 [link removed] 280 - Ariza 800 - Fix - 09/27/06 [link removed]
Username: Pathfinder191 Post Number: 72 Registered: Mar-06
Thursday, September 28, 2006 - 17:29 GMT Thanks Rajesh & Nalin, You guys are life savers! One small problem. I have ariza 750 and with new bin, picture freezes sometimes for few seconds and comes back. Any idea?
Username: Nydas Post Number: 629 Registered: Jun-06
Thursday, September 28, 2006 - 18:29 GMT The ECM is the cause of the interruptions - a hardware solution (in carded receivers) is always speedier than a software solution. Gradually as they implement more ECMs, you may find the slower processors will get increasing problems. Also you will find that these interruptions will reduce over time. Happy viewing.
Username: Sushi Post Number: 7 Registered: May-06
Friday, September 29, 2006 - 21:57 GMT loaded new bin for Ariza 700 now getting all channels except ZEE TV, bad signal or scrambled. Any solution ??
Username: Sushi Post Number: 8 Registered: May-06
Friday, September 29, 2006 - 22:34 GMT power cycled Ariza 700 and now getting ZEE.....
