right cables
Username: Pukka
Post Number: 42
R232 STRAIGHT FOR PANSAT 2500A AND R232C NULL MODEM FOR VS XTREM ? JUST TO BE SHURE I ONLY GOT THE NULL CABLE AND I ALSO HAVE A PANSAT 2500A RECEIVER
THANKS GUYS
Username: Mianruba
hi guys!
i'm new in FTA and a was reading all your posts to have an idea about all this but i didn't see anything about the "MVIDEA" receiver, do you guys thing that would be a new BIN for this Receiver?, i'm asking that because in all the past posts just mencion the Pansat, Viewsat, c00lsat, but nothing about MVidea...
greetings!
Username: Edenman
Post Number: 79
just a quick note about cables, I used 'burial grade rg6' cables, instead of regular rg6 and it helped both signal and quality about 5% or so. and not much more $! sorry if im a bit off topic..
Username: Bhund
Post Number: 99
Mvidea FS4000 FTA Satellite Receiver (MV_FS4000)
http://www.trusssatellite.com/ProdImages/MvIdea_FS4000-.jpg
With it's fast processor advanced features the Mvidea FS4000 Fta is very low priced satellite receiver. It uses a powerful 130 Mhz Conexant chip for faster and better signal transmission. It offers 4 games (Tetris, Gobang, Canvas, Boxman). You can move multiple channels at the same time, edit favorite, rename, etc. You may sort the list in alphabetical, SAT, Favorite, CAS order. Since the screen is transparent, the user can see what is played on the channel. You can see up to 9 windows of channels.
Features:
- MPEG 2 & Fully DVB Compliant
- Wide Symbol Rate from 2 to 45MS/s & Frequency Input from 950 to 2150MHz
- SCPC / MCPC Receivable from C / Ku Band Satellites
- Digital Tuner with Loop Through Output
- LNB Controlling : 22kHz, 13/18V
- DiSEqC 1.0 (Tone Burst), 1.1, 1.2 (Positioner) Support
- On Screen Preview with 16 Pictures
- Caption Support
- Free Switching Background Pictures
- User-friendly OSD Menu with Full Function
- 256 Colors Graphic User Interface
- Multi-language OSD Menu : English, German, French, Arabic, Spanish, Italian, Russian, etc.
- Variable Aspect Ratio 4:3 / 16:9
- Advanced 7 days/24 hours EPG (Electronic Program Guide)
- NIT, FTA / Scrambled Search
- Customized Default Channels Memory Data
- Satellites & Transponders Editing with Add, Delete, Rename, Modify
- Small Screen Picture on EPG and TV Channel List Graphic (P-in-P)
- Supports Teletext through VBI&OSD
- Advanced Automatic Tuning
- Up to maximum 5000 Channels
- Favorites Channel List and Parental Lock Function
- Channel Editing & Channel Sorting
- RS232 Interface for Software Upgrading via PC
- PLL RF Modulator UHF 21 to 69 with PAL I / G / K and NTSC selectable
- Wide Range Switching Mode Power Supply (SMPS), 90 to 275VAC 50/60Hz
- Video, Audio L/ R & Mono Output (RCA)
- 8 Favorite List with unlimited amount of channels added
- 0/12V (100mA max) for external switch (option)
Technical Specifications:
TRANSMISSION STANDARDS
- DVB, MPEG-2
INPUT/ DEMODULATION
- Connector - Type 2X F Type, 3/8-32UNEF-2A (1 input/1 loop through)
- Input Frequency - 950 to 2150 MHz
- Signal Input level - -65 to --25 dBm
- Band Switch - control 22 KHz
- LNB Supply - 13.0 + 0.5 V / 18V + 0.7 V, max 400 mA
- Demodulation Type - QPSK / FEC Coding (DVB prETS 300 421)
- Symbol Rate - 2 < Rs < 45 Mbaud (SCPC/MCPC)
AUDIO/ VIDEO PROCESSING
- Decompression - MPEG-1 layer I and II / Musicam
- Audio Outputs - Stereo Channel / Dual Mono / Joint Stereo / Mono
- Video Decompression - MPEG-2 Main Profile @ Main Levels With Letter
- Video buffer - 64 Mbits of SDRAM is provided
- Data rate - up to 15Mbits/s (Max. burst rate: 228 Mbits/s)
- Video output - PAL-25 frame @720 x 576, NTSC-30 frame @720 x 480
- Video format - 4:3, 16:9
DATA SERVICE PORT
- Connector - 9-pin D-sub female
- Data protocol - RS232C interface. The DVB-DSR is seen as the Data Communication Equipment (DCE) and the PC (or other terminal) is seen as the Data Terminal Equipment (DTE).
- Data rate - Maximum of 625K bits/s
POWER SUPPLY
- Type - Switching mode
- Main input voltage - 100 - 240V AC @ 50Hz/60Hz±5%
- Nominal power consumption - 30W
SAFETY
- Insulation resistance - more than 10M at 500Vdc Ambient conditions of 28 2% & 70% RH
- Withstand Voltage (Hi-Pot) - I/p to O/p: 3kV (1 min)
- Temperature Rise - 75 on winding & core; 50 on casting At 264Vac @ 50Hz
- Safety Standard - Designed to meet IEC 9
MICROPROCESSOR
- Microprocessor - CONEXANT
- Clock frequency - 130MHz
- SDRAM Memory - 8Mbyte
- Flash memory - 2Mbyte
