A Q uestion for the TOP DOGS
Username: Crazy_greek
Post Number: 83
On Galaxy 10R I did a Satellite scan & came up
with sixteen (16) channels.
They all read no info.What am I missing?
Username: Big_fat_j
POTTSVILLE, STONEYTOWN GREEN-LAND
Post Number: 20
Sure your pointed at g10r?
What receiver,dish and lnb?
Just scanned and have 38 chanells.
30 inch dish or bigger and linear LNB?
Signal strength?
Username: Oleg1474
New port richey, Fl Usa
Post Number: 323
loosers loosers!!!
dont give up
my Pansat work good i have most all chanels
new BIN (ECM/EURO06)
Post Number: 84
Hello Toker
The TP Freqs. match with the ones on LYNGSAT.
Receiver Fortec Star Lifetime Ultra.
Dish Fortec Star (90) cm
Motor Stabs HH 100
LNB Invacom QPH-031 output Two (2) Linear and Two (2) Circular.
Can you help? THANKS
Username: Uncle_charlie
Post Number: 100
When you said TOP DOG,I can only assume you meant yours truly:-)
Its like Herb said we need more info.
Post Number: 85
Sure Charlie
If you come up with the fix you will be the BIG TOP DOG.
Post Number: 101
Kavin,just a few dumb questions
Have ya got the latest keys? thats if ya are not auto rollin.
Have ya tried switching on/off at the back or unplugging/plug back in.
Have you got your switches set right
Check your connections etc
Sure ya have done all that,but you never know,its easy to forget.
Post Number: 102
Charlie McCarthy is a silver member with his 101 post.
Ya got to be kiddin me!!! Whats the world coming to..lol :-)
Username: Birdwatcher
Post Number: 444
im f.ucking Top Dog. Anyone have anything to say. If not continue on at ease boys. yall can jack off to a p.layboy instead of Free P,orn
Username: Franktodd
Post Number: 8
charlie is a dog ask him about hucards
Post Number: 446
Id rather watch him do mini dick and danturd doggy style
Username: Dbledragon
Post Number: 92
davidwantsdick, why dont you bend over and STFU!
Username: Minn_rock
Post Number: 300
davidvandicklicker i rather watch your mama doing doggy style with oleg and my dogs..Birdboy..LOL.....
Post Number: 447
its not funny messing with you anymore cuz you say the same ol crap all the time.
Username: Minn_rock
Post Number: 302
davidvandicklicker don't cry my son,why don't u come to daddy and give daddy a little suck..HEHE..
Username: Nfl
Post Number: 31
what a nice couple....
MINN ROCK davidvandickin_a_hole.
Post Number: 86
Iam trying and your guys up with the jokes LOL
Look guys besides Dish alignment could there be something that Iam not doing wright.I know that Iam wright on Galaxy 10R KU. I receive all the channels as listed on Lyngsat Freq. 11720 V tp 1 & 11800 V tp 5 . When I scan it come up NO SIGNAL.
If any of you TOP DOGS don't come up with an answer soon I guess I have to build a set of steps to my roof.
Username: Big_fat_j
Post Number: 21
Whats your lnb freq set at? 10750/standard?
Using a switch?
Signal strength????Leval and Quality???
Sure your pointed at it.No signal quality means either the dish isnt pointed right or the receiver has the wrong settings.Also the LINEAR LNB must be skewed correctly.
Post Number: 87
Hello HERB
Thanks for trying to help.
The only thing that Iam not sure of is the LNBF skew is set correctly. On a motorized dish I was told to set it on 0
Username: Big_fat_j
Post Number: 22
Im using a stationary old primestar dish and lnb.
Dont know about the newer lnbf.When i first tried to hit g10r all i could hit was 121w echo ? and 129W.Found that with the primestar dish the lnb can be turned right,left.There is a skew guage that goes from -45 to +45.121w the skew must be set to +40.For 123w to -40.
The receivers have a skew setting in antenna setup.It has no effect on the lnb im using.Not sure if it effects anything but may with the lnb your using.The 121w and 123w birds are so close together that i can turn the lnb in one direction and receive 121w in the other and receive 123w without having to move the dish.Cant hit both at the same time.
I used a sat finder and found 121w.60% sig.blind scan verified 121w.Skew at 0.
I finaly found 123w just a hair and i mean even less to the west but only got sig.quality at 10% no matter what i did.A blind scan found a couple chanells but not watchable.
Then turned the lnb and had someone watch the sig meter on the receiver go up as i turned the lnb.
Same applied to 129w the skew was the same as 121w.Could hit that bird also easily.Kept hitting 121w and 129w until i changed the lnb skew at the dish.Your lnb may be adjustable from the receiver setup menu.Not sure what it does.When i set the skew for 121w i get 100% sig.For 123w 60% to 100% across the 12 tps i found with blind scan.
G10r is a good FTA sat.Dont give up.
Username: Big_fat_j
Post Number: 23
One way or the other. 121w is + or -.
Would have to go out and check where its set.But one way or the other.
Username: Mickm
Post Number: 85
big fat herb:
have you ever been able to get any of the wild feeds off g10? tp's 11860 11866 11893 11952 12100
12107 12140 12160 12180
Username: Big_fat_j
Post Number: 26
Found something on 11893V(Atlanta operations and scheduling).Signal on 11840v but no chanells found.All others no signal.Only have the vertical side connected on my primestar.Very little on Horizontal anyway.
Username: Perycles2005
Post Number: 20
Hey Herb if you can get some channels on galaxy 10R what channels are those?...locals, spanish,...
Username: Big_fat_j
Post Number: 37
19 english locals.RTNs,FOX,WBs,UPNs,ABCs.Check lyngsat.Several of each.Maybe a dozen spanish.Masmusica some asian.
Post Number: 88
Thanks again HERB
With my motorized Dish I found more birds then I can feed.Will get back with you.
P.S. Now I won't have to build those steps to the roof
Username: Big_fat_j
Post Number: 38
Win some lose some.What was it that solved your problem?Skew?Settings? ????
Glad i could help.
When it comes to TRUE FTA Ill bend over backwards to help.Cause 99% only use for piratacy.To little TRUE FTA info.
Post Number: 89
Hello HERB
On a motorized Dish the skew is set to "o"
I changed the LNBF.Talk at you later.Thanks again.
