Loosing signal on my Dish
Username: Smarcus76
Post Number: 215
hello
the reason im writing is that im experiencing a constant loosing signal on my viewsat,everytime i turn it on i have signal for about 15 seconds sometimes even 30 minutes then the picture freezes and start showing "searching signal" and thats it, but now when i turn on the other box in my room the image comes back for 30 more minutes sometimes hours and hours.. thats very weird, i can't keep the signal 24/7 what am i doing wrong? do you think my DISEQ went? sometimes i can watch tv for 7 or 8 hours straight and then out of the blue starts freezing and freezing. and i have to restart my box in my room for the one in the livingroom to have signal again(thats weird how they work togueder).. can anybody explain to me what is going on?? im very confused.. any help is apreciated..
marcus
Username: Smarcus76
Post Number: 216
Username: Mc_sunny
Post Number: 173
GO TO Antenna setup Option.
first make the signal and Quality level highest as you can
For one Satllite
turn on 22khz-OFF in Antenna setup
and the oter one 22khz-On...i hope that will slove your problem try it
Username: Smarcus76
Post Number: 217
well i have 2 dish antenas one with the echo 8 and the echo7 (twin DP) and the international with echo 3, so i should only leave one on?
