View$at Loader
Username: Starz98
Post Number: 16
I cant seem to get the loader to find a com port. I keep getting error msgs. They say I need a null modem cable. Is this different that what came with it? thanks
Username: Hardrockstriker
Post Number: 491
What, specifically, are the messages? Your cable should say on it if it's a null modem cable. If it says nothing then it's probably just a straight thru.
Username: Kriskros
Post Number: 29
I received a bad cable with the box, I couldn't upload anything. I think the cable was just regular computer cable, not null cable. Sounds like you have the same problem. i had to use null cable from pansat to upload, it worked well. just have the place you bought it from replace the cable and make sure its null cable.
Username: Mrcharley
Port norris, N.j. U.s.a.
Post Number: 22
if it is not a null cable problem I would suggest if you keep your computer on for long periods. try rebooting your computer. I have a dell and have comport problems and know for sure that I am using a null cable. it will not load sometimes because it has trouble with tne comport connection. I reboot and it works.
Username: Dave_kumar
Post Number: 8
need help please . i have a viewsat 2000 palt...
and it dones not pick any sgnal ,it just say searching for signal , why is that ,cant someone tell me what to do.
Username: Jayson
Post Number: 7
dave.....try changing your LNB type to standard....of course that's assuming you have the right bin and keys.....
Username: Bucky_covin
I have tried several times to load my new out of the box VSextreme. I was giving me just an error code. When I check the conection, it says it is connected.
Now it is saying: Resending ZRQINIT and then it says:
Frame Type 255: 70bc 2f f3, but it goes right back to Resending ZRQINIT
But the status bar is not moving and the display on the stb still says noCH.
Is it loading or what?
Username: Jayson
Post Number: 8
bucky....you need to have the rear switch off......just when you press the upload button then you turn the switch on on your receiver.....
Username: Chackboom
Post Number: 14
VS is good. Loader is bad. It takes me 2 hours figuing out to load a file
Username: Timscarlet
Usa
Post Number: 222
i noticed on the new viewsat bins, the satellite setup shows good signal, but when going out into the channels, the signal says "searching for signal", even though i just saw there was a good signal in the satellite setup! i would just never mind the signal at the bottom, and let it autoroll and see what happens like i did. hope it works for you.
Mrcharley,
Thank you,,, I rebooted and everything loaded just perfect the 1st try. Thanks again.
Username: Kll
Post Number: 43
my vsat giving me normal pict than frosen pict and Searching for signal than coming back to normal and than again loosing signal. Any ideas?
Post Number: 10
is there any new key for viewsat 2000 plat
dn.
Post Number: 11
any new kek for dn, i have a viwe sat 200 plat
i have no picture
Post Number: 12
i mean 2000 plat
Username: Bizwhiz
I use my Dell laptop, serial port and null modem cable almost every day. It works fine. But I could not get the loader to see the VS2000 when I tried using my laptop. I rebooted, changed cables, checked device manager, etc.
I tried the same cable on my desktiop computer and it loaded fine.
When all else fails, try a different computer!!
Username: Djsmith
Post Number: 319
text/richtextUpload
viewsatx_setup.rtf (25.6 k)
read
Username: Evadelparaiso
Puerto Rico
Post Number: 1980
Astrovox 2600-Straight DB9
Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, ,etc.)-Null
Cool*sat 4000 Plus-Null
Cool*sat 4000 Pro-Straight DB9
Cooltec-Null
Coship (All)-Null
Digiwave 6800/7000-Null
Digiwave Diamond-Straight DB9
Dreambox (All)-Null
Fortec lifetime-Straight DB9
Fortec Lifetime Ultra-Straight DB9
Lava 2600-Null
Max 2500-Null
****sat (All)-Straight DB9
Microroyal (All)-Null
Pansat 2300a/2500a and all clones-Straight DB9
Pansat 2700-Null
Pansat 3500-Null
Pansat 5000HC-Null(Also can program through USB)
Pantec/Multistar Max (All)-Null
Pantec/Multistar MS (All except MS1000)-Straight DB9
Pantec MX/Ultra-Straight DB9
Rex1-Null
Silver bullet/ST 1000/2000-Null
Skyview 500-Straight DB9
Spacestar DVB500-null
Stealth 2000a-Null
Ultrastar 5000-Null
Viewsat VS2000-Null
