New member Username: Bucky_covinPost Number: 1 Registered: Aug-06 | I have given up on waiting to c@@ls@at cardless fix. Not to mention my two 25ooa's in the bedrooms..I need an unlocked unlooped rev 103 card. I have read here alot to beware of ebay sellers... I have seen alot on ebay with screenshots with the last connect date listed as NONE. How can I tell if it is really unlocked. I am also told to beware of websites, because you can be traced as well..So who do I trust to sell a good card..Any suggestions will be appreciated... |
New member Username: Cucon1Post Number: 9 Registered: Jul-06 | Why bother with a rom1oo2 card, You can buy a VS for a lot less than a card !!! |
Silver Member Username: HardrockstrikerPost Number: 467 Registered: Apr-06 | The way I bought my cards is thru a local buy/sell site in my city. I got the card for less than what it would sell on ebay, there's less of a chance that the seller will try to rip me off, and the site doesn't track transactions as does ebay. So, try to find a local site. Unfortunately, you can't tell just by looking at the card if it's not looped or locked. You will have to trust the seller. Btw, seeing as you already own a c00lsat you're better off going with a card. Because I have a card I've had tv before anyone with a Viewsat since last ecm. |
New member Username: Bucky_covinPost Number: 2 Registered: Aug-06 | Thanks Jason...What significance does "LAST CONNECT DATE" make? I have seen some post that it could not have been connected when we had the last ecm, but alot show NONE. Which is better? |
Silver Member Username: HardrockstrikerPost Number: 470 Registered: Apr-06 | Don't worry about that so much. Just make sure to ask the seller for the revision number of the card, and, if the card has a valid ATR. The revision number must be LESS than 109 or 245 - if it is equal to these numbers then don't buy! Preferably, get a card with rev 103 because they are easiest to unlock. But, you might want to try to get a card that is already unlocked. Good luck! |
New member Username: Bucky_covinPost Number: 3 Registered: Aug-06 | Thanks for all the help.... |
Silver Member Username: VinidominePost Number: 167 Registered: May-06 | dude... just use logic Skyview = 140 bucks Viewsat Platinum = 140 bucks Viewsat Xtreme = 160 bucks rom card = 200+ a leg and an arm Vini |
Silver Member Username: Donnie1973Post Number: 270 Registered: May-06 | i will sell my 102 rev 105 card for 175.00 to anyone. 102's i think will be the best for a while.(till a card swap) i have 2 of them and am currently boycotting ebay. |
Silver Member Username: HardrockstrikerPost Number: 474 Registered: Apr-06 | Yes, I've had "problems" with ebay. They seem to be torn between moral ethics and making a buck. I would stick with the local sites - plus you can get better deals, especially seeing as you can usually pick up the part, so no shipping costs. |
Bronze Member Username: AsharfiPost Number: 19 Registered: Aug-06 | lol |
