Username: Osha Hamilton,
Ontario
Post Number: 58 Registered: Jul-06
Tuesday, August 22, 2006 - 04:41 GMT WHEN WE DOWNLOAD A NEW FILE FOR VIEWSAT SOME OF FREE TO AIRE CHANNEL MISSING IS THERE ANY HELP
Username: Xmongra Post Number: 89 Registered: Feb-06
Tuesday, August 22, 2006 - 04:43 GMT When you download the new bin, you are getting Charlie satellite, you lost everything real FTA.
Username: Hardrockstriker Post Number: 444 Registered: Apr-06
Tuesday, August 22, 2006 - 04:52 GMT As long as you have your lnbs pointing to your FTA satellite(s), and you have the satellites properly configured in your receiver setup, you should still have FTA channels. If you haven't touched your dish, then I would suspect your setup isn't correct.
Ontario
Post Number: 59 Registered: Jul-06
Tuesday, August 22, 2006 - 05:13 GMT SO MY 7 CHANEELS FTA WHAT I MISSED I WILL NOT HAVEING AGAIN THERE NO WAY TO GOT IT AGAIN
Username: Nakadon Mississauga,
ON
Post Number: 1 Registered: Aug-06
Tuesday, August 22, 2006 - 18:42 GMT Great!!! osha now can,a read and wrte english .
Username: Jmill1948 Chester,
Va
Usa
Post Number: 846 Registered: Apr-04
Tuesday, August 22, 2006 - 19:28 GMT try to do a sat scan......
Ontario
Post Number: 60 Registered: Jul-06
Wednesday, August 23, 2006 - 03:58 GMT I DID IT MANY TIME AND I DID SCAN CHANNEL BUT IT STIL FAILD TO SCAN MY MISSING CHANNELL
Username: Evadelparaiso Puerto Rico
Post Number: 1880 Registered: May-06
Wednesday, August 23, 2006 - 04:21 GMT Maybe now you have your favorites channels listed in another number. Check the guide in DN for your favorites channels. Lucky
Va
Usa
Post Number: 864 Registered: Apr-04
Wednesday, August 23, 2006 - 15:40 GMT change the names on the sats to echo 110 and echo 119 this will give you the echostar package it should help..........but you will still need to scan each sat
Username: Mohanin Post Number: 3 Registered: Jun-06
Wednesday, August 23, 2006 - 15:54 GMT MANUALLY ENTER THE THE CH , AND CHK THE SIGNAL STRANTH.. THIS WAY IS EASY..
Username: Hardrockstriker Post Number: 451 Registered: Apr-06
Wednesday, August 23, 2006 - 16:07 GMT Osha, is the proper FTA satellite selected in setup? If so, is the satellite set up correctly in terms of lnb type and switch settings? I'm assuming your DN sats are okay, but not your FTA sats. When you load a new bin, you loose all of your satellite settings as well as channels.
Ontario
Post Number: 61 Registered: Jul-06
Wednesday, August 23, 2006 - 16:51 GMT OKY eva i search in all channels list but stil no thing
Ontario
Post Number: 62 Registered: Jul-06
Wednesday, August 23, 2006 - 16:53 GMT James millard my free channel on telstar 5 i think echo 110 119 it not help i have all channel with echo 3 61.5
Ontario
Post Number: 63 Registered: Jul-06
Wednesday, August 23, 2006 - 16:55 GMT mohan i alerady did MANUALL ENTER THE THE CH , AND CHK THE SIGNAL STRANTH.. THIS WAY IS EASY.. i did it but it said faild scan
Ontario
Post Number: 64 Registered: Jul-06
Wednesday, August 23, 2006 - 16:57 GMT Jason Borne i dont have any problem with setup or switch becuse i have all my free channel exept 7 channel what i want it
Va
Usa
Post Number: 869 Registered: Apr-04
Wednesday, August 23, 2006 - 17:00 GMT 7 may be a spot transponder check your chanels out maybe it is located at another transponder..if not do a transaponder scan
Username: Hardrockstriker Post Number: 453 Registered: Apr-06
Wednesday, August 23, 2006 - 18:03 GMT Sorry, Osha, I misunderstood. Then you might want to delete all of your channels and do a blind scan on the FTA satellite.
Username: Johnner Miami,
Florida
Post Number: 463 Registered: Nov-05
Wednesday, August 23, 2006 - 19:11 GMT Blind scan for all channels and then look for them they'll be there.
Va
Usa
Post Number: 895 Registered: Apr-04
Friday, August 25, 2006 - 02:22 GMT did you get it?????????
