Bronze Member Username: Pannu16Post Number: 83 Registered: May-06 | is there a website where i can find that which direction i shud b facing to find a particular satellite, i am looking to find NSS-6 in toronto!! |
Gold Member Username: The_wank_artistPost Number: 1567 Registered: Feb-06 | http://www.lyngsat*com/tracker/america.html you know the drill. |
Bronze Member Username: Pannu16Post Number: 84 Registered: May-06 | is there a way to find Insat 4A at 83.0°E in toronto i am not clear!! |
Gold Member Username: The_wank_artistPost Number: 1568 Registered: Feb-06 | Yes there is. You would have to pick up Toronto, and move it to the Eastern hemisphere. Unfortunately, I don't think that's a possibility for you. Unless there's something you're not telling us. From Toronto, Insat A4 is below the horizon. Sorry. Use the link above and sellect any of the Sat's in North America. Those you should be able to get. |
Bronze Member Username: Herb_tokerPOTTSVILLE, GRASSLANDS GREEN--LAND Post Number: 69 Registered: Aug-06 | Either that or get 3000 miles of coax and move you dish. |
Bronze Member Username: Pannu16Post Number: 87 Registered: May-06 | thanx for ur help guys, just wanted to double check!!! |
