The Buzz takes Free To Air to a whole new level with the best 7 day EPG on the market today and component output with the Buzz S2010F Plus FTA Satellite Receiver!!!
Product Details
Buzz S2010F Plus FTA Receiver
Fully MPEG-2 & DVB-S Supported : 200 MHZ NEC EMMA 2LL MPEG Chip-Sets 32 Bit RISC CPU 32M Byte SDRAM/2M Byte Flash 16K Bit EEPROM Highly Speedy Channel Changing Time : Less than 1 Sec. 6,000 Channels Memory Capacity for TV & Radio Programs Tuner (Sharp NIM Tuner) DiSEqC 1.0 & 1.2 with 500mA Max. LNB Power Component Output Seven Day Electronic Program Guide
Temporary FTA fixes such as card sharing or emu are listed below.
8/17/06--> Working Temp Fix: Magnum XV3300 (w/ "auxed" Rom102 in the card slot) [emulation] 7/20/06--> Working Temp Fix: C oolsat 4000 (w/ "auxed" Rom102 in the card slot) [emulation] 7/19/06--> Working Temp Fix: C oolsat 5000/6000 (w/ "auxed" Rom102 in the card slot) [emulation] 7/15/06--> Working Temp Fix: SkyView RX600 (with card sharing only) [you have to supply your own cs server access] 7/14/06--> Working Temp Fix: CaptiveWorks CW-600S (with card sharing only) [you have to supply your own cs server access] 7/12/06--> Working Temp Fix: Neosat IPro 1000 (with card sharing only) 7/11/06--> Working Temp Fix: DVB PCI Card (with card sharing only) 7/10/06--> Working Temp Fix: CaptiveWorks CW-600 Premium (with card sharing only) [not a CW release] -need to do a server thru the DB and share that server with your CW Premium. 7/01/06--> Working Temp Fix: Triple Dragon (with card sharing only) 6/30/06--> Working Temp Fix: Dreambox (with card sharing only)
The Buzz which is having financial and legal difficulties is being replaced by Sonicview, which Viewsat has taken under their wing and ownership as well, I beleive....thats why Viewsat, Sonicview and Buzz are all up...same coders and related receivers..Sonicview and Buzz are modified Viewsat bins..
