How do you add channel list?
Username: Machedonul
Post Number: 23
I got the file (it's a weird extension, .GPT or something like that, and none of my software can open this file)...but how do I utilize the file?
using the same software that writes the bin?
please, help me out if you can
thanks in advance
Username: Leew
Ketchikan, ALASKA USA
Post Number: 519
nice web,a lot info, about file extension!
http://filext.com/detaillist.php?extdetail=GPT
Username: Doa
Post Number: 39
I think that's the extention for a GTools file. If you are using Channel Master you should be able to convert it.
Username: Nydas
Post Number: 285
You will do equally well without a channel list but by doing a blind scan if your receiver supports it.
Post Number: 29
i did a blind scan, but i have all these channels WMFR. WRFT, WKSE, i don't know what they are...im guessing a channel list will give you the full name of the channel or just the 4 letter shortcut?? thanks
Username: Nydas
Post Number: 286
Andrew: To a certain extent you are right in pursuing "channel list". You will probably get more info. I get by, by looking at the channels, shortlisting some in my favourites, and putting a little extra info manually. I will see if I can come with an answer to your original question. In the meantime, if you have the answer, just post it here.
Post Number: 30
so i guess my question is for those people that already have channel lists:
are you guys/gals showing the full channel names or the same 4 letter extensions as myself?
Username: Doa
Post Number: 41
Those are Locals from around the country!
If you want the DN names edit your channels (it's an option on your receiver)to display by SID.
Post Number: 32
thanks DOA
i pretty much re-named a lot of channels, but let's face it there are hundreds of channels, i cant do them all
but once i get home, i will do the SID thing
thank you
Username: Pas2roc
Florida USA
Andrew check this out and see if this is what u r
looking for.
h**p://www.lynsa*.com/uslocal/index.h*ml
* = Letter " t "
Username: Jmill1948
Chester, Va Usa
Post Number: 831
do the blind scan if you can its more........
Username: Osha
Hamilton, Ontario Canada
Post Number: 44
what u mean a blind scan
