Thinking about a Viewsat
Username: Detroitd
Winton, Ca. U S A
I currently have a pansat 2500 I knows all the ins and outs of this reciever, I am considering getting a viewsat platinum as a secound reciever, my Question to all the profesional pirates out there is if the viewsat is as easy to program as a pansat and does it require the same procedure such as loaders and bins.
Username: Shayeileen
Post Number: 18
I have decided to go to viewsat as well f#ck this pansat bulls#it. Good receivers but Blacklist and his programmers are garbage. I heard they all went out and bought receivers that worked as well!! So now they are chillin with their beer watching ppv
Username: Meyou
Post Number: 18
All boxes are pretty easy to program. Unless money is no concern to you I would hold off to see what the next ECM brings. No knows how long VS will be down when it happens. VS claims they have the full map and if that is true then getting a VS isnt a bad idea. However, if they are down for a week or more again, CS with auxed card might be a better route.
Username: Detroitd
Winton, Ca. U S A
Thanks for the Info.
