FREE PPV
Username: Bazuka2020
Post Number: 330
cp AL7BAR
Free PPV Movies.
Hope this isn't a repeat of info already posted. Hollywood Hits PPV shows current release movies. The movies play on a 12hr cycle (4 or 5 movies then repeat), and change throughout the week. It can be found on the C-Band side of Galaxy 10R @123*. Setting are Polarity: 3949V Symbol Rate: 05582 A monthly printable schedule can be found at www.libertycommunications.com./DTV.html Click movies in lower right hand corner.
Some of the movies showing this week are Syriana, Aquamarine, Underworld: Evolution, The Hills Have Eyes, Pink Panther, along with many others. Also it lists showing the Roy Jones fight "live" tomorrow night.
Good luck to all,
Gizz
Username: Pu239_enema
Post Number: 52
hmm, i may aim my big plate that way today and check it out, thanks for the info Khan
Post Number: 331
Let me know what and how you get it, i have a 33" dish dont know I can get it or not
Good luck
Username: Mybig_willie
Post Number: 183
6 Foot or better.
Post Number: 332
Thanks Big
Username: Pirate_pete
Post Number: 309
"C" band need BUD big ugly dish.
Username: Tazman632000
Post Number: 8
is the signal encripted?
Username: Northman
Post Number: 144
Thanks Khan. I set my big dish to G10 ( 123-deg. )& did a blind scan, because the channel wasn't listed on Lyngsat. I had the 3 stations with Bluegrass, Classic & Southern Gospel on Vertical & the Outdoor Channels East & West on Horizontal. This PPV channel, if that is what it is, is called TV 301 after a blind scan & is on 3.948-Ghz Vertical, symbol rate: 5580....showing a horror movie right now & I'll post the real channel name if I see it. Thanks again!
Post Number: 338
Thanks northman for the info, i guess I have to do some research to get a BUD. Thanks for sharing info - thats why we are all here
Post Number: 193
Yeah more of this and less of the other.Good info.
Username: Northman
Post Number: 145
Khan, that's why some of us are here anyway, but not
a large percentage of the riff-raff. Carry on!
Oh, by the way, mine is a 10-ft. dish with a 39-inch ku-band dish & 18-inch DSS dish mounted to it, partially blocking the c-band dish's surface, but even with a 25-degree noise LNB, I am getting 90 to 99-percent signal quality, so I guess that a 7-ft. dish would still work OK, if you aren't able to get a 10-footer.
Post Number: 340
Thanks
Username: Northman
Post Number: 147
Between movies, the channel shows "PAY PER VIEW"
"Hollywood Hits without the Hassle"
Now it's showing the Pink Panther movie with Steve Martin.
By the way, there are 4 choices for audio tracks ( 2 languages in Dolby AC3 & 2 languages clear ( English & Spanish ))
Post Number: 341
Dear Northman
Can this dish get what you are getting? Thanks
120cm KU Band Offset Dish Antenna printer-friendly version
FORTEC STAR 120cm KU Band Offset Dish Antenna.
Model FC120CM
Specification
Value
REFLECTOR
Type
Offset
Offset Angle
24.62 0
Diameter
120 cm x 132 cm
Aperture Efficiency
75% min.
C -- Band Gain @ 4.0 GHz
32.78 dB
KU -- Band Gain @12.5 GHz
43.32 dB
F/D Ratio
0.6
Focus Length
720 mm
Material
Galvanized Steel
Finish
Polyester Powder Coating
Color
Grey / Cool Grey
MOUNTING
Mounting Type
Ground, Pole & Wall Mount
Adjustment Type
AZ / EL
Elevation Angle Range
25° - 77°; 17° - 90°
Azimuth
0° - 360°
Material
Steel
Finish
Color
Grey / Cool Grey
Pole Diameter Acceptable
45 -- 75 mm
Net Weight
17.0 kg
ENVIRONMENT
Operational Winds
25 m / sec
Survival Winds
50 m / sec
Ambient Temperature
-40°C ~ +60°C
Relative Humidity
0 ~ 100 %
Copyright © 2001-02 Fortec Communications Inc. All rights reserved.
Username: Phong2210
i have been read all post, but i still don't get it. what is BUD? what is receiver, and which dish?
can anyone give me some detail?
thanks
Post Number: 343
BUD = Big Ugly Dish
Receiver = The equipment to process the signal from Dish to TV like Pansat Viewsat etc
Username: Nestea
Post Number: 10
Can i get this channels with eliptical dish?
Username: Northman
Post Number: 150
Big ugly dishes ( 10-footers ) are the best for consistent C-band reception & the 4-section mesh ones like the Unimesh were always the best. If you're looking at a used one ( taking one down ) then look at the dish from the side to see if it is still flat ( not warped out of shape ). The better the mesh condition the better. Also, the dishes with mounts for an actuator arm are better than the horizon-to-horizon mounts, which are weaker & more problematic than the actuator motor type, which can be quickly changed or exchanged with a new motor, rather than being stuck with a gear box that doesn't work. I have had limited success with dishes as small as 6-ft. for c-band, so I would not recommend 1.2-meter ( 120-cm ). For individual channels, you can sometimes get information from Lyngsat or Satcodx for continental signal levels, with suggestions for minimum dish diameter, according to where you actually are in North America. LNBs with 25-degrees noise or lower work the best.
Post Number: 348
Thanks Northman
Username: Phong2210
thanks Khan
any idea where i can buy one BUD, and what is brand name?
Username: Northman
Post Number: 151
There should still be some dish repair guys around that have a small stockpile of dishes that were removed when DTV & DISHNET came out. ( Scavenger hunt ).
Username: Abbas1
Khan;
Can you please help me to get my setallite working again;
Today it stop working;
I changed the keys 5 days ago only !!!
Will appreciate your help;
My email is: mekdam1@yahoo.com
Thanks.........
Username: Min
Post Number: 280
THE KEYS JUST CHANGE AGAIN,GO LOOK AROUND FOR THE KEYS MAN,OR U NEED ME TO COME OVER TO INPUT IT TOO...
Username: Jcanavati
Post Number: 71
Is this Galaxy PPV stuff just to burn time while the new FIX arrives, or have you guys given up hope on new BIN?
Username: Zott
are you using a c band receiver and lnb or are you using a side car and ku lnb or are you using a fta receiver and lnb TO GET THIS PPV FEED ON G10 @123' PLEASE SPECIFY so I can put up the right setup and get me some PPV
Username: Northman
Post Number: 159
Hey JCC, certainly we haven't given up on the coders. If we had, then we wouldn't be checking back here so often.
The movies on this station are the ones currently on the BEV & DN PPV, so be happy & start watching. For HBO & the rest of the specialty stuff, you always have choices: subscribe, don't subscribe...stuff like that.
Username: Spanishbabe
Post Number: 8
hi guys anyone can help me like sending me the link or the file for the rom 102 I have try to uplowdit from my old files and nothing happen please help me
e-mail kidstec@msn.com
Username: Ohdeerhunter76
what do i need to do to set up that sat plz help im new sorry if in wrong post
Username: Northman
Post Number: 161
Hey Spanishbabe, find a post with rom 102 stuff. We'll keep this thread for the C-band free PPV channel.
Hey Mike, do you have a c-band dish you need instructions for?
