Missing channels again
Username: Kumudinia
Post Number: 31
I have entered the latestes keys listed below in my Viewsat Xtreame. Got the local channels and CCN/HHN for three days and from yesterday I am not receiving any channels. Autoroll off and did blind scan also. Still no channels. Please tell me how to fix this. Thanks!
Key 00
0F C5 21 D1 B6 04 8E 9E
90 CC D3 12 58 E4 B6 9B
Key 01
71 9C 60 71 04 C1 39 AE
88 FF F0 5E D2 4C F3 FC
Username: Donnie1973
Post Number: 217
have u power cycled it?
Username: Kumudinia
Post Number: 33
Please tell me what is power cycled? What I did was turn off the FTA for few seconds and turned in on. Still no pictures.
Username: Pu239_enema
Post Number: 80
If you take 2 minutes, not much more, just two tiny minutes to read the titles of a few of the upper most threads that have been posted in the last 24 hours you may stumble upon other threads discussing the recent KEY CHANGE, yes they changed the keys and the new ones have been posted, read people, is easier to read than it is to post a new thread everytime u need something as simple as a key.
Username: Keyisme33
Post Number: 17
there the wrong keys moron cycle it all you want ya aint getting crap ilmao loser
Post Number: 81
Dude, just to save bandwidth, u dont need to cycle anything, the keys are wrong and u obviously dont want to read around, here are the darn keys:
key00=0FC521D1B6048E9E90CCD31258E4B69B
key01=430F1985B78014631B7AFCE3F7EADC2B Active
cheers
Username: Djsmith
Post Number: 137
key change on August 02
https://www.ecoustics.com/electronics/forum/home-video/254844.html
Post Number: 82
This is one of those times when u wish there was an active mod/janitor to flush all the garbage threads/posts on this Forum, not only there are no stickies and good/decent information is quickly buried with tons of lame threads, peeps dont hessitate to keep doing it lol
Username: Kumudinia
Post Number: 34
But in my viewsat I have line 88 and 98.
Username: Bertoro
Toronto, Ontario Canada
Post Number: 73
88=00
98=01
Username: Slo_hand2
Post Number: 455
The new keys work GKA as stated above
88=00
98=01
Username: Bassi911
Post Number: 28
I have an Ariza 700 and these keys never worked for me
Username: Djsmith
Post Number: 142
New key change Aug.3
Follow these step by step instructions EXACTLY using your remote control.
Press MENU
Pres DOWN and highlight PARENTAL CONTROL
Press OK
Press DOWN to Second pin
Press 0 0 0 0
Press DOWN (select AUTOROLL OPTION)
Press OK
Select KEY CODE (make sure it is ON)
Select Dishnet Auto-roll (make sure it is OFF)
Press EXIT
Press DOWN and select NAGRAVISION 2
Press OK (you should see DISH NETWORK in the Provider ID)
Press DOWN to get to KEY NUMBER
Key number is now 00. ( if not, press the left arrow key, not the 0 button )
Press DOWN. (to key DATA)
PLEASE REFER TO THE TV SCREEN to PRESS THE CORRECT BUTTON TO PRODUCE THE LETTERS A - F
line 1 = DE E9 OB 22 87 B4 B6 33
line 2 = C3 E4 3D 59 F9 22 7C 67
Press OK to store the change.
Press UP arrow to KEY NUMBER
Press RIGHT arrow to change to key 01.
Press DOWN.(to key DATA)
line 1 = 43 0F 19 85 B7 80 14 63
line 2 = 1B 7A FC E3 F7 EA DC 2B
Press EXIT several times to exit all MENUS. WATCH TV.
NOTE: Both keys must now be correct for this to work.
Please make sure the keys you enter are EXACTLY what is written on this instruction sheet. If you enter a key in the WRONG position, IT WILL NOT WORK.
Username: Zunna
Post Number: 37
Are the indian chanells comin with these keys??
