I am newbie, and I am just looking information to explain me how/where can I enter keys manually after the bin is installed (I have Fortec Star Life Time Classic NA). By the way actually I lost all the channels from Nimiq Satelite (bell Express view, Canada), And If anybody help me even if only to get local channels, I will be Very Happy
Hi just read how to enter keys press menu go to parantal control second pin (0000) or (0101) go to autoroll option off all press ok go to nagravision 2 press ok chek for Id provider 09 01 enter 00 key press ok enter 01 key press ok watch tv
I don't Know if I am NULL at this point but all what I have in my Menu is parental Lock (in Config folder) . When I press enter hi ask me to enter Pin, When I enter The Pin hi ask me to enter My Pin and enter twice my new Pin (something like changing my PIN). So where can I find my Nagravision. Please Help me to get started..
1-click MENU on the remote 2-right arrow to Channel Manager 3-down arrow to CODE 4-enter 1001 5-right arrow until you NAGRAVISION into the top left corner 6-down arrow until you select DISH NET (provider id will be 00 and 01) 7-click OK on the first DISH NET (00) 8-into the next screen, down arrow to highlight KEY VALUE 9-use the LEFT and RIGHT arrows to change values (you cycle through letters / a,b,...e,f and numbers / 0,1,...,9) 10-click on the red button (save and exit) 11-click on EXIT 12-WATCH TV!
Thanks for your Help. Now, I know how to make ( Thanks to you) can you PLEASE tel me where can I find Code for My fortec to see at least local channels here in Montrel. (I know That there is no Fix -- new bin-- for now)
In my fortec I have The latest Bin for Bell Express View (BEV), so what I am looking is the code to see chanels of BEV CANADA (or only channels still working). Otherwise, Is-it Normal that in my Nagravision I Can't incorpore more then a couple of 8 number (but your code is 16 of couple number.
what bin do you have ? 277 bin is the working one. for fortec
Follow these step by step instructions EXACTLY using your remote control.
Press MENU Pres DOWN and highlight PARENTAL CONTROL Press OK Press DOWN to Second pin Press 0 0 0 0 Press DOWN (select AUTOROLL OPTION) Press OK Select KEY CODE (make sure it is ON)
Select Dishnet Auto-roll (make sure it is OFF)
Press EXIT Press DOWN and select NAGRAVISION 2 Press OK (you should see DISH NETWORK in the Provider ID) Press DOWN to get to KEY NUMBER Key number is now 00. ( if not, press the left arrow key, not the 0 button ) Press DOWN. (to key DATA)
PLEASE REFER TO THE TV SCREEN to PRESS THE CORRECT BUTTON TO PRODUCE THE LETTERS A - F
line 1 = 0F C5 21 D1 B6 04 8E 9E line 2 = 90 CC D3 12 58 E4 B6 9B
Press OK to store the change.
Press UP arrow to KEY NUMBER Press RIGHT arrow to change to key 01. Press DOWN.(to key DATA)
line 1 = 71 9C 60 71 04 C1 39 AE line 2 = 88 FF F0 5E D2 4C F3 FC
Press EXIT several times to exit all MENUS. WATCH TV.
NOTE: Both keys must now be correct for this to work. Please make sure the keys you enter are EXACTLY what is written on this instruction sheet. If you enter a key in the WRONG position, IT WILL NOT WORK.
oh and Just so you know I cant get my fortec to work with bev using that bin I gave to you. If yours is different please tell me where to get the one you have .
My bin is somthing like This 'LT Classic NA_060613.bin' I got it from DssTester. So I havn't Idea if is the latest because It relatevlly old (Jun 13). Otherwise, I am verry confused becase I stil Have problem to Enter the godes you give me because I havn't Line 1 and Line 2 in each DISH NET (provider id 00 and 01). So What I have is exactelly what monster told me above. So Please Help to input this Keys for Bell Express vue, (what is AUX86, I can't find-it in my NAGRAVISION)
Sorry djibo, only DN has any channels up at this time. You can try all you like but I think in the end you'll only have wasted you time trying to get BEV. You might be able to get some local channels using the old 'rabbit ear' form of testing.
