I've had 2 receivers now, since the last electrical storm on Monday, blow the voltage regulator for the LNB, & with the regulators removed, both receivers do the same thing ( on powering up, they both start with 8.8.8.8., then - - - -, then 8.8.8.8., then - - - - ). Can they be revived or are they history? I know I can get new LNB8 voltage regulators, but they are not responsible for this display problem. The units will not load bins, & I'm wondering if I should make up a jtag for them ( 20-pin ). Any one with similar problem in the past. Thanks.
....update....I now have 3 receivers doing the same, after the LNBP8 voltage regulators were damaged...same boot-up sequence on all 3: first: 8.8.8.8. then - - - -, then 8.8.8.8. with various 8's being a little brighter, then alternating, then - - - -, and the sequence continues...will a jtag factory flash help, because the units will not take bins through the serial port ( cable is good... works on good receivers of the same model ).
...update..knowbody fcuking cares azzhole..that is why other people arn't posting...take you problems and go tell your counsellor, maybe he can help you...ROTF
