Telstar5 and skyview rx-600
Username: Younes
i have an SKYVIEW RX-600 abd a 33inch dish with a low freq LNB but i stii can`t get telstar5 the quality bar is at 71% but no strenght .
any ideas?
Username: Concorde
Post Number: 13
got the wrong frecuency set
you need a universal lnb(linear) capable of 9750 to 10750 frec. if you do, set as follows.
lnb type universal
lnb frec 9750 to 10750
try to input this transponder 11986V or 12022H
those transponders will give you a strong signal
Username: Younes
i used the angle calculator to make sure i have the right settings.still can`t get it to show
Username: Younes
i use the angle calculator to make sure i had the right settings,still can`t get it to work
Username: Younes
under LNB type i only have two options normal or ocs-dp,any clue?
Username: Concorde
Post Number: 37
what is normal? if normal means standard . that only means you are stock with dish or Bev programing.
your receiver cannot get linear fta. check the manual about lnb types use
Username: Younes
i can not find a reciever that has Linear fta and it`s feature?
Username: Younes
Post Number: 7
so the new SKYVIEW RX-600 is not good for anything else then dish i guess?that sucks because i thought it was one of the best out there.what a Disappointment
Username: Younes
Post Number: 8
does anyone know of a cheap receiver that can get linear fta?
Username: Abdou91
514
Post Number: 37
younes verifie if the 22 ..khz is on
Diseq
Username: Younes
Post Number: 9
yeah the 22khz is on ,i am pluging it directly to the LNB so no Diseq
Username: Brittny
can someone please tell me the new file for skyview rx600 receiver, its been down for two weeks now!!!!!!!!!!!!!!
Username: Younes
Post Number: 10
you should be able to get local channels until the fix come out but the whole point here is that, can you use the skyview to view channels in telstar5?
