C-Band again, at least they have HD now !
Username: Alienloco666
Sunrise, Florida USA
Post Number: 18
Hi
Can someone please send me some info, until the fix is out I want to get the C-Band, I have the Pansat 2500a and 36" with Dual LNB, where do I have to point that sucker ?
Any help will be great !
Thanks
Alien Loco
Username: Cybercubi
Post Number: 97
I don't hink a 36" will do you any good with C-Band, you need a much bigger dish and also C-Band lnb. Check lyngsat.c0m for c band birds.
Post Number: 19
I think you are correct I did some checking, and that is going to be a problem, my complex will go crazy if I get a larger dish..
What can I get with the 36" dish and pansat 2500a box ?
Thanks
Alien going more loco every day !
Username: Cybercubi
Post Number: 99
LOL - Well you can get a few FTA channels on IA5 - 97W, but mostly foreign; you can also get some channels on B3V Nimiq 1 at 91W, but mainly its US local channels now and the sports channels, TSN, SportsNet, what have you. You can always get GolTV from DN, if you're into that at all. Other than that, not much out there bro...
