Dish Pro 500 pointing to BEV. Help.
Username: Impala1977
Post Number: 28
I have DP 500 Trying to tune in to nimiq 2 and 1.
I am keeping the same set up I had with DN. I am having a hard time getting the right Elev. and Skew. Azimuth may be okay. Nimiq 2 has quality but 1 does not. Anyhelp help appreciated. Thank you.
Username: Moe948
Post Number: 50
If Nimiq 1 has no quality and nimiq 2 doesn't then move your dish only a little bit west wards and see what happens.
Username: Da_bin_chi_code
Post Number: 77
Isn't it east (not west), and few degrees up (elev)?
Post Number: 29
Thank you moe, scanning as I'm typing. BIN Chi, I moved it just slightly west and a few degrees up(elev). The quality:
Nimiq 1= 77
Nimiq 2= 48 (still in the green)
I am more concerned with getting 1 than 2 because from reading here there may still be some quality channels on Nimiq 1.
Anyway, thank you guys.
Username: Navy_seabees
what skew did you use on your dish 5oo?
Username: Storyteller
Post Number: 76
http://vps.arachnoid.com/satfinder/
install in puter..always have it...great for the dish 500
Username: Woofy
Ontario Canada
Post Number: 257
Ernesto...this site will give you a very accurate look angle for your dish 500.
http://satcalculator.freehostia.com/
Post Number: 33
Thanks Story and Mike. That is the site that I used and I installed satfinder. Great tools.
Navy sea, the sites given here can help you out. I founf out when it was calculated you'll get a negative skew, not sure what tool I used but all you have to do is substract that number from 90 degrees.
