The best FTA sateliite to point my dish !
Username: Alienloco666
Sunrise, Florida USA
Post Number: 11
Hi
Well looks like we are not going to have a fix any time soon, so I have netflix and I want to point my dish to a FTA or 2 FTA satellite, I have a dual LNB with Dave dish 18"
Can someone please tell me what is the best satellite to point that sucker, so I can get more channels
Thanks
Alien
Username: Tadon
Dover, NJ Usa
Post Number: 97
point your dish to SAT. 91 . At least you have somting to watch .
If you have two LNB before watched for 110&119 .
Now, you turn your dish and til up . 110(LNB) look for 91 and 119(LNB) you will get 77W (77W have few HBO & channels). Hope this help
Username: Lakers1
do i need to put keys to watch 91, Le? Ca'm o*n nhieu
Username: Omgu2
bui le,
can my dn superdish also pickup intelsat ameri 5 at 97W or the galaxy 3c at 95W?
Post Number: 13
Hey
Thanks
Yes that will help...
Hope the fix will be out soon
Bye
Alien
Username: Letmeon
Post Number: 54
What is at 77W?
Username: Shafto
Cooper City, FL USA
This may sound like a stupid question but if you are going to get 2 sats with one dish do you split the difference between the sats and point the dish there or at one and adjust the lnb for the other one? Example on the 91 and 77 where would you point before adjustments?
Username: Van1
Post Number: 12
Correct me if I'm wrong, if you get 91W with 110W so should get 100W with 119W...I don't see how you get 77W ??? Normally with the same antenne you can get 82 and 91 without problem..
Username: Banzai
Post Number: 67
Peter,
You have to get 1 SAT first (1LNB = 1SAT) and fix position of your dish, then get another SAT(s)
Username: Creek
Smithtown, New York
Post Number: 141
Upmanis, Echostar 4 is 77W.
Point to Echostar 4.
Username: Tadon
Dover, NJ Usa
Post Number: 99
Hi Kieu Pham,
you need input key number for BEV.
D1 15 0C 8E 66 82 D9 80
90 A9 20 20 37 07 87 08
0C B7 0A F9 50 75 F3 5B
31 EC 79 97 5C D7 CE 1A
*** Turn autoroll off before input .
My dish 36", pointed 110 & 119 Then I turn
to 91 with 110(LNB). After I do LNB setup for
91 with 110(LNB) . Then I play around (by remote cocntrol) with 119(LNB) by change SAT. to see
what signal 119(LNB)will be intercepted . So I get Echostar 4 is 77W. (Actually I dont intend
to point 77W just accidentally). Hope this clear .
Username: Tadon
Dover, NJ Usa
Post Number: 100
I am very sorry about your name Ken (spelling wrong) !
