C-band channels
Username: Jawaharyousuf
Post Number: 11
Hi,
can i get C-band channels using an Universal LNB? I have a 33" dish with this lnb that is pointing to 121W. What type of LNB should i need for C-band?
Post Number: 12
and by the way, whats the difference between LNB and the LNBF? Which one's the one that sits on the dish, and actually receives the signal? the above post is in reference to that one.
Username: Waydown
Post Number: 32
low noise block amp(lnb)
Post Number: 13
which one is that though?
Username: Waydown
Post Number: 34
for a c-band ,it depends on which reciever you use.old one uses LNA and a Down converter,Newer one uses a LnB ,which has down converter built in.
Username: Waydown
Post Number: 35
what receiver do you have
Post Number: 14
fortec lifetime ultra
Post Number: 15
so you are saying all that matters is the receiver i have? No need of a special LNB/F?
