CaptiveWorks First Out With Temp Fix
Username: Watzupwitu
Post Number: 18
Got this from another site, don't know how true this is;
HEHEHE Where is Viewsat and thier Card they claimed worked in the Vod Videos.NOT!!!!!!!
This is a card sharing temp fix to get Dish only back up and running. We are working on a final fix as is all the others. We have not had time to just swing by and chat but we are working on it so bare with us.
1.fix the pix problem in nagra2 channel...
2.add cardshare function...
-do F1 555 enable ecm cardshare..
-how to run cardshare watch current dish channel:
-you need the extra tool to run the cardshare
-connect the receiver to computer with a NULL cable and make sure
computer is -connected to the internet.
-open the tool csc.exe
-goto setting-->option->setup correct com port
-goto setting-->start...
-load the new 1.19 firmware on your Premium box
-then go on receiver do F1 555(make sure patch is enabled F1 000)
-if you have correct setup you will see the ecm come on the tool and cw
-Now only dishnet is setup, bev and new other providers will be setup
soon...
have fun...
PLEASE NOTE THAT THIS IS FOR PREMIUM BOX ONLY AND ITS A BETA VERSION
TO SEE HOW SERVER WILL HANDLE THE USERS. FOR REGULAR CW-600 A NEW
SERVER NEEDS TO BE SETUP. THIS WILL BE A STABLE BACKUP SOLUTION WHEN THE
CHANNELS ARE DOWN. CODERS STILL WORKING ON THE REAL FIX AND ITS LOOKING
GOOD.
