New member Username: BjpPost Number: 1 Registered: May-06 | Can BEV is catchabele in Los Angeles area. I like to get Nimiq 2 (82W)and Nimiq 1 (91W). Based on Nimiq 2 Satellite footprint it is looks like on edge of the cliff. Any one has pickup Nimiq 2. Nimiq 2 82.0W Long Azimuth - 127.3 Azimuth - 113.0 Elevation - 34.3 Skew - -41.1 |
New member Username: Asandy1234Post Number: 3 Registered: Jan-06 | After DN was down I switched to BEV ,I had no problems with Nimiq1 got all 13 Prn channels and PPV but when I tried Nimiq2 which has the ethinic channels it takes almost 10 min for each channel to load ,once loaded there is no problem.Is there any solution for this. |
New member Username: BjpPost Number: 3 Registered: May-06 | Thanks Andy, Now I will try it Nimiq 2. By the way what is the percentage level you are getting...I am interesting Internation channels. |
Gold Member Username: The_wank_artistPost Number: 1081 Registered: Feb-06 | Depending on where you live in CA, you'll need a big dish (up to 90+") if you can get it at all. Here is a map of the footprint, if this isn't the one you referenced already. http://www.kusat.com/go.php?path=/install/foot-display.php?nickname=nimiq |
