Help me to conect 2700A
Username: Vbalasho
Portland, Oregon Washington
Hi to all,
Please help me to conect my 2700A. I am going crazy. It is only see one sat. Echo8.6 It does not see sat # 110. 5 have several switches and also have Dish 500 Sat. PLEASE HELP
Username: Bazuka2020
Post Number: 20
Echo 8 is 110 west echo 7 is 119 west, from behind the dish 110 lnb is on right side 119 on left side and a little higher. get the highest signal on 110 w I mean echo 8 and do a blind scan. or be specific about your question?
Username: Vbalasho
I HAD DISH NETWORK. THEY INSTALLED THE SAT. AND BEFORE I SAW 119 AND 110 WHEN I DID "CHECK SWITCH". NOW I DO NOT SEE "ECHO7". DO I NEED TO MOVE THE DISH?
Post Number: 21
Was your pansat working before?
What kind of switch you have?
Go to installation select sattelite Echo 7 and look at the settings when you see disque try turning it on and of and see quality changes or not
Username: Vbalasho
I bought pansat which was never used before (NEW). Also sometimes I get full signal on 110 and 119, but later on TV shows no signal
Username: Wakenbake
Post Number: 235
did update cable and switch come w/2700a,
dn probably used sw-21,use diseq switch,
diseq#1 119
diseq#2 110
Username: Vbalasho
Post Number: 7
the only help, i need to conect the dish with receiver. i haveD-2100lx duplexer (950-2250/40-860MHz) , pansat 4x1 Diseqc and dish 123254(950-2150MHz)
Post Number: 24
One more question, is your pansat has a flash or its in original form. If its in original factory setting you have to do some reading, search etc.
Username: Highlander
Can Someone please send me the new key code for dish network? Does it matter what reciever I have? Do the Pansat 2700a and 2500a use the same key code? I have the 2700a....Thx. in advance
Username: Min
Post Number: 31
DN
KEYS=01--ACTIVE
71=9C=60=71=04=C1=39=AE
88=FF=F0=5E=D2=4C=F3=FC
but no ppv and xxx ,everyboby is waiting for the fix ....
Username: Maff
Coamo, PuertoRico Coamo
I have Pansat 2700A I need code pin for setting
Username: Abuashar
I have pansat 2700A and put these keys, but didn't work. Can someone help me? Thanks
Sk
Username: Min
Post Number: 35
abu , after u enter the keys turn your receiver off from the back and turn it back on , or u have to turn off the autoroll too ...
