Key # 's for Dish Network (Pansat)
Username: Sthames7
does anyone have the key number for pansat dishnetwork niagravision2
Username: Monst
Post Number: 19
Here you go Steve,
KEY86: E8 70 B0 0A 8E 0A 3D C5 F3 59 C3 5F 1A DA 19 5C
KEY96: 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC (Active)
Username: Kool2
tommorro after 3 pm new keys will be posting
Username: Auitc1
Post Number: 13
THESE ARE WRONG* KEYS MONSTER* !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Username: Radames
Ponce, Puerto Rico
Post Number: 8
Your PPV is down?
Username: Min
Post Number: 28
they are the right keys paul , after enter keys turn off from the back receiver and turn back on , or turn off autoroll ...
Username: Min
Post Number: 30
radames ,everyboby ppv and xxx are all down ,have to waite for the fix ...
Username: Bazuka2020
Post Number: 22
Its not the key problem buddy, wait for the new fix
Username: Cricketer
Montreal, Qc Canada
pukhtoon khan........ when the fix is expected???
Username: Ryles
Lodon, Ontario Canada
Post Number: 10
monster what is keys 86 and key 96, i thought pansat was 00 and 01 and if you dont mind explaining what do mean by 'active' and is there a way to select what keys are active
Username: Bandizzy
Mi Usa
Post Number: 57
86 = 00
96 = 01
Username: Viet004
Post Number: 16
my ppv is ok everything work fine except xxx
Username: Min
Post Number: 32
don , active mean that is a cuurent keys , or a latest keys a newest keys so and so ...
Username: Lklives
Post Number: 3631
This is NOT the current Dishnet key 00 but I keep seeing this still posted at many sites for 61.5 and 121...try it
N 0101 00:
98 F7 44 AC 5E 07 D9 ED 8A FF 3B 7E 65 71 F9 4E
Needed for 61.5 and 121
N 0101 01: (active)
Username: Hotdagobabe
Post Number: 38
0101 01
PPV SOME OTHER DOESNT WORK, PROLLY THE BIN,
this works beter than monsters,
Post Number: 39
wow LK great minds think alike, if all had keymaster, there wouldnt be soo much whining??
Username: Dhruv10
HI
can this key work for fortec star liftime classic na.
and if so, then when i try to put the code in Dish Net Provider 00:01 Key 00 there is only 8 column in Key data that means 18 alphabet or Number but there is 32 letters or alphabets or am i doing something wrong in putting the code.
thanks in advance
Username: Rossyjess
Post Number: 10
works for all fta
