Switching from dn to bev
Username: 5abi
Post Number: 10
hi, im currently on dn with only one satellite at 61.5 echo 3, since its down and i dont get my internationals im thinking of switching bev.
is this possible with my current set, i have a pansat 2500 clone, one satellite with one lnb.
where do i move my satellite to and what changes would i have to make in my recievers menu etc.
any help would much appreciated
thank you
Username: 5abi
Post Number: 11
also is one satellite enough for all bev channels or will i need additional satellites or lnbs
thanks
Username: Hardrockstriker
Post Number: 154
You will need 91 deg satellite for bev. There is also 82 deg satellite but most channels are on 91. You can use your current dish, just repoint it. You will have to set your antenna setup to get Nimiq 1.3/ku. Also, put in lastest bev Nagra2 keys (provider id 09 00).
Username: Vinidomine
Post Number: 88
I think... you should wait. by the time you get bev they might be running ecm too. it all depends how accessible your dish and know-how.
Vini
Username: Tenpercent
Alabama
provider id for bev is 09 01. i believe most of the internationals are nimiq 2.
Username: 5abi
Post Number: 12
thanks for the replies, since bev might also have a ecm, is starchoice a good alternative for now?
