I have a viewsat extreme and was having some problems locating a satellite. My question has to do with the on screen menus. When you are on the screen checking the satellite signal strength, you move to the satellite you are trying to connect with. Then when you lock onto "a" satellite there is black text that appears on the top of the screen. Does this indicate the satellite that you are actually connected with? even though its different than the one you are attempting?
