GlobeCast satellite
Username: Bnc
Many Globecast channels are dead. Are any attemps to fix it?
Username: Bnc
It seems like no one care about South-East Asian Channels on Globecast T5
Username: Cybercubi
Post Number: 46
Sorry Bud, you'll find very little support for GCast here. Are you talking about nagra coded channels? Irdeto coded? Have you done a new scan to see if they have been moved to a different TP? Do you have the latest bin installed?
Username: Bnc
I scanned TelStar 5 every few days but there are no luck. I think Globecast did the same as Dishnet and Bell did last week by blacking out PPV and movie channels.
Username: Mrkvip
Phnom Penh, Kandal Cambodia
Post Number: 28
I want to know too.
Username: Outlooker202
Post Number: 7
same here
that why i post this thread
https://www.ecoustics.com/electronics/forum/home-video/239877.html
only to get useless replies
Username: Lklives
Post Number: 3454
Globecast keys are impossible to find and GC has NOT been included in Blacklist's bins for quite awhile..
Post Number: 8
who say their using BL boxes.
Username: Lklives
Post Number: 3455
BL put out many bins with GC..box is irrelevant!
Post Number: 13
LK,
Make up ur mind is it in it or NOT in BL bins.
I know for a FACT w/ Clone safe bin GC is in.
Username: Boyce
Post Number: 263
For I understand, it is not the key, they doing like Dish did, need new fix for it.
Username: Lklives
Post Number: 3473
as I stated BL has not had GC keys in his bins for a long time... I don't know which clone safe bin U are referring to, but BL didn't write it..must be talking about the 2700 272v1 bin, cause its not in 277T..was in 273T in March!
Username: Bnc
Post Number: 7
Finally we get LK to share his knowledge. May be BL can tell us when we can expect get GlobeCast back.
Username: Bnc
Post Number: 8
Anybony knows where to input these keys for Globecast:
IDEEA key 86
IDEEA key 96
Username: The_wank_artist
Post Number: 961
Check under nag1 settings.
I think I've seen Globe there in the Pansat 2700, but I can't say for sure as I've never tested Globe nor changed the keys for it. Only seen it.
Username: Hardrockstriker
Post Number: 108
I've got Pansat 3500sd with bin 3.52 and has keycodes for 3 providers (DN, Bev, and GC?) and in has an autoroll on/off setting for GC, so I'm assuming the latest bin supports GC.
Username: Tbedoya
Bayonne, Nj Us
Post Number: 13
can i have dn keys
Post Number: 974
DN:
E8 70 B0 0A 8E 0A 3D C5
F3 59 C3 5F 1A DA 19 5C
71 9C 60 71 04 C1 39 AE <-Active
88 FF F0 5E D2 4C F3 FC <-Active
These are the last ones I've seen for GlobeCast. Don't run it so I don't know if they are accurate or not. If someone can let me know.
EB 4A C4 1A 45 5B DD 23 <-Active
54 7E EF 4B 3A BF 4D 62 <-Active
83 20 3C A8 E5 7B 93 A6
7B 12 67 AB 40 62 03 B1
Username: Mrkvip
Post Number: 29
Not working!!!
Username: Bnc
Post Number: 9
The problem is not in the key codes. I think GlobeCast uses the same methods as DN and Bell recently did to PPV and Movie channels. Then again, this is just my guess.
Post Number: 110
Bud, the video decode algorithm in the bin applies to all networks, so if bin fixes problem for one network, and all networks are using the same ecm, then it cannot be the bin.
Did you loose all channels or can you still see a few? If so, then it's not keys or ecm, maybe deleting all channels and doing a blind scan will bring them back.
Also, did you loose channels exactly at the time when you installed new bin, or, did new bin work for a while?
Just a few things to think about.
Username: Mrkvip
Post Number: 31
I can see a few channels.
Post Number: 998
Mrkvip,
You use GlobeCast obviously if you see channels.
Where have you gotten your keys for it previously?
I've tried finding them but with little success.
This is the only site I came across with them but they were outdated from what I was told.
http://www.rdi-files.com/nagra2.php
Username: Mrkvip
Post Number: 32
I did. But it isn't working.!!!
Thanks.
Post Number: 999
Cool.
If you ever find a site or op that runs the keys can you post. Would like the option of having them to both test and provide.
Username: Bnc
Post Number: 10
I rescaned T5 today and got 172 channels. I randomly test many of them. Around 40% of the channels I tested are working and 60% of them said scramble or bad channels and wait for pictures. Many free FTA channels are not working.
Username: Bnc
Post Number: 11
Anyone else cares about Globecast: South-East Asian and Middle East channels?
