Superdish 121 only pickup vertical TP's w/ pansat 2700a
Username: Alpha11
I have a superdish 121 and on my 119 sat when I am doing blind scan at the start it scans all H's & V's later it finishes at 50% only picking up the verticals and the horizontals are wierd numbers like 15323,15352 with 0 quality and they supposed to be 12xxx I deleted all tp's and reflashed bin and scanned again to the same effect my setting are.
119 sat
dish pro lnb
freq 11250
22khz off
disq #1
so could it be my switch or LNB ?my quality is in the upper 90's thanks for any help.
Username: Alpha11
thanks for the help you fucktards I had a legit question and nobody answered but you guys can keep on answering everybody elses really really stupid ?'s but I got it from another site thats you guys are jokes.
Username: Bandizzy
Mi Usa
Post Number: 46
are you using a disq switch or a dp34. run it direct and see if it fixes it.
Username: Bandizzy
Mi Usa
Post Number: 47
i think you only need verticals? dish pro?
Username: Bandizzy
Mi Usa
Post Number: 48
a factory reset might help?
Username: Tatou
Edmonton, Alberta Canada
ihave pansat2700a igot nothing but bad scrambeld channel need fix plz
Username: Cosmic_ray
Toronto, Ontario CANADA
Post Number: 91
New BIN for PANSAT 2700A
Thanks !
