Only get 61.5
Username: G0dm0de
for some reason my cw600s is locked on to the 61.5 sat. i try to scan on other sats but i only get internation channels
can anyone help?? i was getting all channels from 119w before the ecm
Username: The_wank_artist
Post Number: 1000
ajdhasd,
Check your DiSEqC settings.
Make sure your ports are selected correctly in the antenna setup.
61.5 port one (guessing how you have it set up) and 119 port two.
Both the actual DiSEqC switch and antenna settings.
Lucky!
