Eva: for fortec star life ultra : 277t bin fil or 275t better?
Username: Lada
Montreal, QC Canada
Post Number: 9
Eva, thank you very mach!
I have now BL updater 1.4, but not shure can I use: 277t or 275t bin fils?
Thanks.
Username: Nunosondra
Post Number: 12
I'm using the 277T and it works perfect on my f0rtec lifetime ultra. If you use this bin file don't forget to set the default key!
Jeepster
Username: Terrakun
i have ultralife fortec can't find khmer ctn chanel. anyone out there have any idea? thanks
Username: Lada
Montreal, QC Canada
Post Number: 19
Help me please! I have Fortec Ultra, Uploader Bl 1.4,DB9 Cable- f/f serie 6pd 9f/9f. When I try Write Bin I have a message:Can not open serial port!!!
Acces isdenied. when I change Port1 for Port3 I have message: Downloading, and after; Write faild (ER1)
What I need?
Thanks.
Username: Evadelparaiso
Puerto Rico
Post Number: 902
Lada:This file is for all pansat and Ultras Recivers
Upload this file to ur reciver.
Then go to menu...
Panternal Control...
Second key (1668 password)
And set defult keys..
Exit everthing
All channels r back
http://www.dss***tester.com/files.php?cat=14
lada remove *** register is free. Lucky
Puerto Rico
Post Number: 903
Lada download the last gtloader.
Puerto Rico
Post Number: 904
Lada post your email and i will sent you the files.
Puerto Rico
Post Number: 905
And 277t is safe for ultra.
Username: Lada
Montreal, QC Canada
Post Number: 20
Eva thanks alot for your help,
my email is : zhanettai@yahoo.com
Username: Edith
Toronto, Ontario Canada
Hi,
Does Bin 277 work with DN?
Thanks!!!!!
Puerto Rico
Post Number: 919
the bin are different for each model or brand, which receiver do you have Edith?
Username: Dixon_buts
Moon Base Alpha 1, Red Square Mars
Post Number: 22
Unless you have a retard computer the serial port will always default to port one unless the computer has more than one serial port. Just use a monitor extension cable they always work.
Username: Edith
Hi Eva, I'm new with this stuff and thanks to this site I was able to make my Ariza work again. Now I'm trying to help my siter fix hers she has a Fortec Star Ultra Lifetime Receiver but I heard in another thread that the new bin was for BEV and not DN. Is this right?
Thanks again.
Puerto Rico
Post Number: 939
You can download the new bin for all ultra at http://www.dss***tester.com/files.php?cat=14ultra.
This bin fix Dn too. remove ***
remember download Bl loader or GTroam loader.
Username: Variuscr
Lada, if your problem still isn't fixed try this (using the COM3 that gave you write error):
https://www.ecoustics.com/electronics/forum/home-video/239505.html
Username: Zenabo012002
HarareZimbabwe
I'm in Zimbabwe and have lost all the codes for Sabc1, Sabc2, Sabc3, Etv and Btv on my Fortec Star. Please could someone help!!!!!!!
Username: Giideh
eva iwas told u r te best helper. i have a dead fortec ultra. how can i revive it. please give me link for help.thks
Username: Lklives
Post Number: 3336
Jtag..ALL Dss sites have the info...good luck!...next time use pansat 2500 CLONE safe bin like the 277T..
Username: Miauu
Gabi mouth to mouth hehehe!!
Thank u for all the help Eva(Edith my Sis)
Username: Thakkar2000
hi guys...i got my cable...i couldnt find a straight cable so i have an adapter inbetween...now i m tryin to download the bin file, 277T using fortec stb updater 3.1A but i get the "wrong model name" error. plz help..plzzzzzzz
Username: Lada
Montreal, QC Canada
Post Number: 23
When I use GTRom Loader v3[1].35 with fill 277T, for Fortec Ultra,sink me message: UNknown file type?
What I do wrong?
And can I use this file 277t with AL7BAR DOWNLOADING TOOL v1.31.?
Tanks.
Username: Piccalo
Post Number: 29
Lada and Bhavik use Blacklist Loader V 1.3 ... should work
Username: Trackster1991
Eva Diaz, I have a Fortec ultra and i was haveing trouble with it can u send me every thing i need to know? At Trackster1991@yahool.com I need a loader a bin and a software to unzip a file please.
I would really apperate this Thanks a lot for your time.
Username: Lada
Montreal, QC Canada
Post Number: 24
PT... I has right before tried BL Loader V 1.3 and again message: WRITE FAILD(ER1)
Username: Piccalo
Post Number: 35
Lada - are you using rc 232 striaght through cable with DB9 females at both end?
Username: Destine1983
Montreal, Quebec Canada
Post Number: 103
just making sure,forgive me if I am asking this again,but is the bin
X-85BL_060610_277T_au_api_
good for FOrtec Ultra Lifetime Ultra?
Puerto Rico
Post Number: 942
Lada you dont unzip the file. Unzip the bin file.
Username: Piccalo
Post Number: 37
yes that bin file should fix it.
Puerto Rico
Post Number: 943
Yes Lada, you can turn the back button off wait a minute turn on and start again. The backbutton reset factory settings. Try and let me know.
Username: Piccalo
Post Number: 38
hey Eva have a question... does QSAT 2500PLUS use the same bin as Pansat 2500a...would appreciate the reply.
Puerto Rico
Post Number: 944
Julie: yes its safe for ultra.
Username: Lada
Montreal, QC Canada
Post Number: 25
PT...Yes. I have DBP F/F Cable-6ft SERIE 6PD 9F/9F prix: $6.00
I think, I have problem with a ports COM1 or COM3 on my PC?
When I used COM1, I have message: can not open serial port!!!
Access is denied.
When COM3 : Write Faild(ER1)
Puerto Rico
Post Number: 948
Post Number: 8
Username: Piccalo
Post Number: 39
Lada try this...
1.Power down receiver and computer!
2.Connect receiver to computer and power both of them up!
3.Start up gtrom newest version and select the new bin file you wish to upload then click download wait until it is finished it will go to a 100 percent but it is not finish until it displays burn complete or finished!
4. Turn off power to receiver and computer and remove the cable from the receiver!
Username: Lada
Montreal, QC Canada
Post Number: 26
EVA/ I already this tried!!!
What I do wrong?
Maybe I have problem with a ports COM1 or COM3 on my PC?
Thanks.
Puerto Rico
Post Number: 950
Harry go to dss**tester.com remove ** Pansat area, download the last bin for pansat and ultra. Go to search try LOader, download the gtloader or bl loader, Go to www.winzip.com Download evaluation copy its free. Unzip both files. And follow the instruction how to run a bin file
For ALL Pansats....
Things you will need!
1.A computer with a com port!
2.The right cable to connect to your computer to your receiver!
3.GTROM LOADERv3.34 or newer!..or another loader like BL 1.4
4.New pansat 2700bin!..or another Pansat bin
5.LNB setup and the right switch!
6.Sat Signal at 70 percent or higher!
3.Start up gtrom loader v3.34 or newest version and select the new bin file you wish to upload then click download wait until it is finished it will go to a 100 percent but it is not finish until it displays burn complete or finished!
4.Turn off power to receiver and computer and remove the cable from the receiver!
5.Install cable from the lnb and the cable from the tv and the plug it up and power up the receiver!
6.Using your remote hit menu and the parent control then ok in second pin enter 0000 and then ok!
7.Then set default key..EMU-ON then ok!
8.Go to Nagavision2 then ok and check 00 and 01 keys. Put in new keys if need then hit ok to save!
9.Now installation then ok antenna setup then ok make sure you have 110 and 119 and check to make sure the switch is set right for both on the diseqc setting! If 110 is on 1 and 119 is on 2, set diseqc the same way!
10.Now go to blind scan and hit ok!
11.When finished exit menu and watch tv!
Before start to run a bin turn off the back button in your receiver. Lucky
Puerto Rico
Post Number: 951
Fortec Lifetime Ultra-Straight DB9 The right cable for ultra.
Username: Terrakun
Username: Miauu
Hola Eva when u say BI loader do u mean BL just asking if that was a spelling error.... the only loaders i found are bl por pansat r u referring to those or do u know of an specific one. If so could u let me know... I have fortec star lifetime Ultra Gracias
hi ...thx guys..this is wicked...my fortec lifetime ultra is back on!!!..i used BL updater as u said n it ran beautifully..thx alot guys!
Jenny
[link removed]
use the BL loader from here...it worked for me while others didnt...i have fortec lifetime ultra too...file 19..hope itworks
Username: Miauu
Post Number: 7
I need the files for my fortec star ultra lifetime please send me somebody can I use the ones from pansat 2500 clone at fta central for my fortec EVA? cuore2401@hotmail.com thanx bhavik i'll try anybody has an answer to this post please
jenny
bin file
[link removed]
Username: Miauu
Post Number: 8
How do I unzip them
do i unzip them when my box is connected and the computer asks me to extract all files is that what u mean bhavik or do i do it before connecting my box and uploading the bin
and thank u so much for helping me
Username: Miauu
Post Number: 9
bhavik
do u have the loader could u send it at cuore2401@hotmail.com because the site is not letting me download it Pleazzze
Username: Mrkvip
Phnom Penh, Kandal Cambodia
Post Number: 21
Hey Lada.
Your computer don't have problem with your com1 or com3. It from your recevier.
It can't use DB9
It can use Jtag (in your box 20 pins)
Username: Vipulseema
Hi Bhavik,
I am trying for past 1 hr to upload loader and bin files for fortec star receiver
And noluck, (Only VIP members)
I would appreciate if you can email me those files at vipul.seema@gmail.com
Thanks in advance.
Vipul
Username: Lklives
Post Number: 3376
Bin 277T and BL updater 1.4 are here too..
here's ALL the Pansat bins, loaders, Jtag manuals, input key Guide, etc...
[link removed]
Remove the * in both links...also must register first FREE www.dsscommunity.c*om
Username: Giideh
why am i being bombarded by emails. all i did is asked a question. help on how to stop this. thks
Username: Giideh
where can i find a virgin fortec IRDmem. mine got bombed
Username: Giideh
Post Number: 7
277T works fine on fortec lifetime ultra. I have 3 of them. one was bombed by the 277.
Username: Giideh
Post Number: 8
i thought keys were embedded in the bin. if this is incoorrect please advise. thks
Username: Giideh
Post Number: 9
there is a new bin for LT classic NA at
http://www.dssevolution.com/forums/showthread.php?t=69336&highlight=NA+classic
Username: Urooj
Hello Lk thanks for reply man, as you said i did rescan after checking my switches and setting my disecq to correct numbers but stil im not getting all the channels on echo3,echo7 and 6.8 iam missing some internatonal channels as i told before that i have FLU and i uploaded _060610_277T_au_api_ and did defult key update i got some 50 chanles on echo 3 and alltogether some 180 chanels but missing some india and sports chanel for cricket strange thing is that i uploaded same bin for my cousin and he got every thing including PPv and international and i help my friend with his FLU and he has same problem as mine I tried re-loading the bin 85BL_060610_277T_au_api_ again but still same problem should i do factory reset and upload this new file, but iam afraid that i will lose every thing i dont how to bring it back after factory reset Please help all the expert personals LK,Eva any one please please..greatly appreciated thanks...Urooj
Puerto Rico
Post Number: 988
Urooj If you have fortec, turn off back button, set your receiver and rescan. If you still have the same problem try to download channel master for your receiver.
Username: Urooj
Thanks every one i re uploded the same bin and did Blind scan and now i have all chanels. thanks
Username: Wakenbake
Post Number: 205
nice
Username: Sstwired
I've been playing with a Fortec Lifetime Ultra for about 8 months, had no idea what I was getting into. Found the satellite forum sites, read, read, still lost, confused. I read every post in as many forums I could find.
When the problem hit I decided to attempt the fix myself.
Read, read, read, found what I was looking for, loaded a Fortec STB Updater and the 277t fix. I followed posted instructions.
After half a day of screwing around, found the Fortec Updater does not work, period. Delete it.
Read, read,read,found the "Blacklist STB Updater 1.3 exe" file, had TV up and running in about 10 minutes.
Follow posted instructions - This is what I did:
1) Download the new fix (277T) and unzipped it. You will get a .Bin File
2) Opened the BL loader, copied the .Bin File to the loader.
3) Turned off the receiver from the back switch. Connected the serial connector. (9 pin straight thru cable for a Fortec) COM 1 to RECEIVER
4) Turned on the switch on the receiver. As soon as the first green light appeared on the receiver hit the "download/fix" button in the updater screen.
5) Now started downloading the .bin to the receiver. (Wait till it goes to 100%. WAIT till is says "Complete" and the Receiver reboots.) Done!
6) Connected the receiver back to the dish and the TV. I did not have to rescan, had all available Channels.(110 & 119) At that point most all scrambled.
7) Go to parental controls, go to second pin, enter 0000, and then hit "select default key". Exit Exit All OK
Everything working perfect, all channels, EPG better than ever.
Thanks to Forums like Ecoustics.
Username: Miauu
Post Number: 13
sstwired where did u get ur BL updater 1.3 could u please send me site
thanx
Username: Sstwired
Jenny
I found that BL loader on the HasHHu site, in the Files and Downloads Forum, sorry, I never bookmarked the thread, it took forever to find it, I was so excited and in a hurry to try it.
Go to the Hashhu site and use their Search.
Good Luck.
Username: Haxit
Eva Diaz can you please send me the same files as you sent Lada. I am in the same situation. The only problem is that i don't know what cable to use for my Fortec Liftime Ultra.
Thanks
My email is: karatehawk@gmail.com
Username: The_wank_artist
Post Number: 973
HaXit,
Fortec Lifetime Ultra uses a straight DB9 cable.
Username: Edith
Hi!
Can somebody please tell me which are the correct cables for Fortec lifetime ultra?
In the begining some people were advice to use the RS232 modem cable(cross over type)but now I've seen that they are advicing to use the the RS232 straight type does this make a difference?
I have a RS232 cross over type which worked perfectly with my Ariza 700 the first time I used it, and now we've been trying to fix my sister's Fortec lifetime ultra for a week already!! We have been doing everything we were told to do, using the RS232 null modem cable(cross over type)now I wonder if we've been using the wrong cable?
Please someone Reply and Thanks.
Username: Samm
I downloaded the new bin 277 for my fortec ultra, everything is back in order but I'm not getting the arabic channels as i did before (lbc, art...)
can anybody help
Thanks a lot
Puerto Rico
Post Number: 1098
Fadi: Delete all channels and scan again, maybe its an issue with tp. If you still have the same problem try reading in post about another users with the same problem. I will look around and will read about that problem, and will post if I can find any information.
Puerto Rico
Post Number: 1099
Edith: if you use the wrong cable, do not wili get communication between pc/receiver.
Puerto Rico
Post Number: 1103
Edith: and the ultra use straight cable.
Post Number: 986
Actually Edith, it's a straight 'DB9' cable.
LOL :-)
Puerto Rico
Post Number: 1105
Tyler Knitting channels...
Post Number: 987
You should have seen the shows tonight.
Afghans, sweaters and sox!!! It never ends. There are so many options with Knitting.
Oh the joy!
Expect a scarf and hat this Christmas Eva, not that it'll do much good in PR!
Puerto Rico
Post Number: 1106
I hate knitting channels. O_0.
Post Number: 988
How can anyone hate the Knitting channel????
And it's a capital K when you talk about Knitting!!!!!
Get on board Eva! :-)
Knitting is your friend.
Username: Snasser
Hi
Anybody have the link for the fortic star
thanks
Username: J_sort
hi!
anyone know where can i download manual for fortec lifetime ultra? I need to know how to setup channels in favoriate.
john
Puerto Rico
Post Number: 1134
Said which you want? the link for?
Puerto Rico
Post Number: 1135
john: check your email
