NOT Getting ALL Channels on 119
Username: Xtrawest
Post Number: 8
i'm missing lots of channels on 119, and wen i go abt doing blind search(power scan) on Ariza 750CX, it only find 41 program, anyone got idea, wat should i do..?
Username: Xtrawest
Post Number: 9
few TP's are getting failed when i do SAT Scan on 119, getting only 41 programs, LK u got any idea?
Username: Wakenbake
Post Number: 222
best to PANIC
get whiskey
swear @TV
Username: Lklives
Post Number: 3531
Realign the dish and make sure your receiver settings (antenna/LNB, disque port) are all correct for the 119 bird..
Username: Xtrawest
Post Number: 11
come on wakenbake, if u know wat should i do.. just leme know plz...
Username: Wakenbake
Post Number: 223
rescan
you dont need me
Username: Xtrawest
Post Number: 12
thanks LK, i realigned the dish, its working now.. thanks again, U ROCK..!
Username: Wakenbake
Post Number: 224
if so advanced
that YOU can align dish in 13 MIN
why post here
Username: Bandizzy
Mi Usa
Post Number: 17
if it takes you 13 min to line up a dish your not advanced
Username: Wakenbake
Post Number: 225
then help
a--hole
Username: Wakenbake
Post Number: 226
or should i call you
sherbert
Username: Bandizzy
Mi Usa
Post Number: 19
sure call me what you want.
Username: Bandizzy
Mi Usa
Post Number: 20
this stuff isnt hard level plumb pole scew elevation little to the right left lock it down watch tv.
Username: Wakenbake
Post Number: 227
then theres NO problem
Username: Abdou91
514
Post Number: 12
hi
chech if you csan all type of channel when y do yr blind scan
Username: Satmans
need bin file 272 where can i get it
Username: Wakenbake
Post Number: 229
do what works
for you
the man
Username: Satmans
this is the fix for the 2700a what i have been told and then down load ch list
