Detroit locals wanted but live in south?
Username: Sowhatsowhat
Post Number: 7
Topic says it all. I have a 3500sd, when the system searches for the channels it skips over them. Is there something I can do or is it impossible since I live in the south? I get a lot of locals but most are down here. Any help is appreciated, or any knowledge on the topic is also appreciated.
Username: Hardrockstriker
Post Number: 95
Some stations are conus - they get broadcasted to all/most of North America. Some stations are spot beamed - they get broadcasted to specific areas (e.g. Detroit) within a 100 mi. radius. Chances are that the local stations are spot beamed, so you're out of luck. But, if you really want to find out, check out lyngsat*com (replace * with a dot). This site lists all channels, and also says whether they are spot beamed or conus.
Username: Giideh
Post Number: 19
i too live in south. when u find out. pls let us northeners know. thks
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 88
you have to get a bigger dish and that might work
i miss nothern stations also
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 89
oops northern
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 90
this might help ya
http://ekb.dbstalk.*om/297
just add c for com
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 91
if that don't help then here
http://*ww.google.com/search?hl=en&lr=&newwindow=1&q=satellite+spot+beam+map
Post Number: 8
Yeah, it looks grim. Thank you for your posts though.
