2 recievers on 1 dish?
Username: Namstick
can someone tell me if your can get 2 recievers on one dish working if so explain
Username: Tadon
Dover, NJ Usa
Post Number: 31
2 Receiver:
for EX . you are looking sat. 110 & 119
with 2 LNB (dual). You need 2 DISEQC to
get two output .
4 short cable (X<1m long) run form LNB
SAT.
110 ---> cable A
110 ---> cable A'
SAT.
119 ---> cable B
119 ---> cable B'
Parallel Connected:
DISEQC #1 : 110A & 119B ----> output 1
DISEQC #2 : 110A' & 119B' ---> output 2
**** DISEQC : Remenber what port # is connected
You will apply for setting up in
your receiver .
So you have 2 Receivers .
Output 1 ----> Receiver 1
Output 2-----> Receiver 2
have fun. - Buile
Username: Banzai
Post Number: 30
if you have T90 dish you can get 4 SAT and also depending on the LNBF that you currently have (max to 4 receivers as Invacom Quad Polar LNBF)
Username: Lada
Montreal, QC Canada
Post Number: 27
thien cang... thank you alot for advice yesterday!
But I do not have in Device status COM3.Ther are
Port(COM & LPT):
Communications Port(COM1)
ECP Printer Port (LPT), and in Port Setting for LPT there are LPT1.LPT2,LPT3.
I do not understund what is that mean?
Thanks.
Username: Lklives
Post Number: 3346
U can get 10 receivers with 1 dish with the right combinations of switches and LNB's!
U still can't even figure out how to flash your receiver...U should subscribe..or take a simple basic 5th grade computer course..SERIOUS!
Username: Tadon
Dover, NJ Usa
Post Number: 32
Lada,
COM = Serial port (Communication port. Usually PC talk (use program) with other ...)
LPT = Parallel port (Line Printer Terminal. usually use for printer)
LPT port is bigger than COM port
Using COM port (in this group)to upload BIN
(it means PC talk with Receiver)
Username: Lada
Montreal, QC Canada
Post Number: 29
Thanks, bui le ,but when i use COM1, I have message: Cn not open serial port! Access is denied.
What i can do?
Username: Tadon
Dover, NJ Usa
Post Number: 33
Lada,
You can use any COM from PC . But you need to
tell program "Loader"/ or PC a location of cable is connected (what COM port). For EX when you run Loader :
@ COM setting, default set: Serial port = COM1
but if you connected RS232 to COM 2, You have to
change your setting is COM 2 .
I don't know what COM you are connected. But if your PC have 3 ports, you don't know which one you connected, The only way to do is : DO 1 by 1 .
Asume your PC has 1 port . That is COM1
With the message , I guess due to cable. Check
cable/connection/do step by step slowly ...
I don't know what your system is, but I recall
many thread is talking about NULL and STRAIGH cable . Which one you need, you must read and find out . Hope this help .
May be experters from this group will help you out .
Username: Lada
Montreal, QC Canada
Post Number: 33
bui le,
I tried use COM3,but I got Message: Write Fails(ER1)?
Username: Lklives
Post Number: 3363
write failed is either wrong cable or comport!...she probably has USB oports and doesn't even know it..and FTA receivers do NOT like USB ports usually!...she previously stated she had a Fortec Ultra which needs a straight (NOT null modem ) cable..and BOTH cables look IDENTICAL!
Username: Giideh
Post Number: 21
lada
COM = Serial port (Communication port) 9 pins on back of computer.
LPT = Parallel port. 25 pins also on back of computer.
connect stb box to computer using com port (9 pins)
use BL loader.
choose COM1 (in program)
download from computer to stb box.
do not disturbe until download is complete.
set keys
download channels
enjoy watching
gl
ps: dont' be upset with wise remarks. many think they'genuises. think all the rest are common. keep comming back for help. many are nice people.
