Bev keys
Username: Blackcove
does anyone knows the keys for bev and how do i input these keys in .helpppppppppppppppppppppppp
Username: Nickb
New York, New York USA
Post Number: 40
Hey..
I think these are the new kes for BV.
But what receiver are you using??
86
D1 15 0C 8E 66 82 D9 80
90 A9 20 20 37 07 87 08
96
0C B7 0A F9 50 75 F3 5B
31 EC 79 97 5C D7 CE 1A
Username: Blackcove
Post Number: 8
i have a pansat 2500a thanks
Username: Rich728
new keys for dn as of june 13 pansat receiver
Username: Nickb
Post Number: 41
Hey...I got this from a previous post...
How to Update Public N2 Keys for Pansat 2500a
1. Menu button, then scroll down and Select Parental Controls goto 2nd PIN/enter 0000 or 1668
2. Scroll down down to Nagravision 2 press OK.
3. On the Provider ID,it should read 0101 if not use your right volume button, then you will see dishnetwork right above the provider ID box.
0101 is for Dishnetwork Keys
(BEV KEYS ARE 09 01)
4. Scroll down to key number box.
5. Make sure Nagravision 2 on the top left, and key # is 00, in the KEY DATA box, enter the new N2 key 86.
6. Make sure Nagravision 2 on the top left, and key # is 01, in the KEY DATA box, enter the new N2 key 96.
7. Confirm the N2 key 00 & 01 are correct, then press OK to SAVE the new key. The press EXIT a few times, and you will watching TV...
key 86
key 96
