Pansat 2700-n2 problem
Username: Eclipse_the
i just got a pansat 2700-n2 and been trying to load it. i have serial port and such. i have loaded bins onto a 2500 clone. but i cant seem to get it to upload any of the 2700 bins into the 2700 i know the 2500's are timing senstive (wont load if you wait too long) is there a trick to loading a 2700 for the first time
Username: Bandizzy
Mi Usa
Post Number: 10
X-87BL DownLoader 3.4? + 272 bin Make sure the reciever is on. no trick.
when i do that it never moves above 0 percent.
this reciever is a virgin never had anythigng done to it
Username: Evadelparaiso
Puerto Rico
Post Number: 906
The 2500 and 2700 do not use the same cable, 2500 use straight cable and 2700 use null cable.
Puerto Rico
Post Number: 907
Pansat 2300a/2500a and all clones-Straight DB9
Pansat 2700-Null
Pansat 3500-Null
Pansat 5000HC-Null(Also can program through USB)
Pantec/Multistar Max (All)-Null
Pantec/Multistar MS (All except MS1000)-Straight DB9
Pantec MX/Ultra-Straight DB9
Username: Jcolon
Centro, Puerto rico Centro
Post Number: 13
Hi Eva did you know wich is the new bin file for pansat 2700? were i find it?
Puerto Rico
Post Number: 910
Juan, yes, is already posted go to dss**tester.com and download the bin for your receiver and loader, check is you have clon or original receiver before download, for 2700 box use a NULL cable. Rs232 Lucky
Username: Lklives
Post Number: 3332
Use this bin for pansat 2700 clone or genuine..its the 272v1 bin
[link removed]
Username: Jcolon
Post Number: 14
Eva ,I dont know how to find it ! What can I do?
Username: Jcolon
Post Number: 15
tank's LK!
Username: Vasia22
Post Number: 10
hi anybody know how to jtag FORSAT 2500 ultra?
Username: Lucia
Post Number: 33
what kind of cable does it use?
it's pansat 250
