Some PPV channels missing on B*V
Username: Tariqic
Post Number: 33
there are some PPV channels missing on B*V. Does anyone know what the problem is, if there is any or do I need to perform a different type of channel scan? I have performed a Blind Scan a few times but same results. Thanx in advance.
Username: The_wank_artist
Post Number: 876
Try a sat scan.
Username: Tariqic
Post Number: 35
Tyler, the options I have are "Blind Scan", "Auto Scan" and "Manual Scan". Thanx
Post Number: 877
Go here.
http://www.lyngsat*com/packages/expressvu1.html
Do manual scans and find out if it's a specific transponder that is not coming in or not.
Perhaps you may have to tweak the dish a bit?
Also, double check your settings in antenna setup.
Username: Woofy
Ontario Canada
Post Number: 178
T..if you are using a cool sat 5000..and i think you are..then use the auto scan option with network search on(never blind scan for the 5000)..that should bring in all available channels for you.
Username: Tariqic
Post Number: 36
Rob, Tyler, thank you. I'll try your suggestions. Have a good day.
